Solid lifter/bushed lifter bore question #913814
01/25/11 05:37 PM
01/25/11 05:37 PM
NORTHERN CA
HUSTLESTUFF Offline OP
NORTHERN CA
I'm building a low deck 512 with girdle and bushing/re-aligning the lifter bores. I plan on using a solid lift cam (old STX 22) with mushroom lifters. Do I need oiling holes in the bushings. Thanks in advance, Mike.
Re: Solid lifter/bushed lifter bore question [Re: HUSTLESTUFF] #913815
01/25/11 06:19 PM
01/25/11 06:19 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
IF YOU OIL THRU THE PUSHRODS
home of the
Sox and Martin Hemi Duster
Re: Solid lifter/bushed lifter bore question [Re: HUSTLESTUFF] #913816
01/26/11 03:10 AM
01/26/11 03:10 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My is to go ahead and drill them. My undrilled bushings showed some odd wear patterns that might have been indication of insufficient lubrication. I've since drilled them to eliminate that as a possibility.
Re: Solid lifter/bushed lifter bore question [Re: BradH] #913817
01/26/11 03:18 AM
01/26/11 03:18 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
make sure holes are located exactly as for lifters used. . wrong and you could experience loss of oil presure
home of the
Re: Solid lifter/bushed lifter bore question [Re: BradH] #913818
01/26/11 02:55 PM
01/26/11 02:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I like to have a small hole drilled in them for some lube, a little running down the lifter onto the cam on a flat tappet isn't a bad thing .
Re: Solid lifter/bushed lifter bore question [Re: HUSTLESTUFF] #913819
01/26/11 03:00 PM
01/26/11 03:00 PM
My 440 block has .030 or .060(can.t remember which size ) oil holes in them, it is a solid roller lifter motor not oiling through the pushrods to the rockers.
Re: Solid lifter/bushed lifter bore question [Re: HUSTLESTUFF] #913820
01/26/11 07:17 PM
01/26/11 07:17 PM
AndyF Offline
AndyF  Offline
I'd put a small oil hole either at 5 oclock or 7 oclock. You don't need it that way for the solid lifters, but you'll want it that way if you go to a roller lifter down the road.
Re: Solid lifter/bushed lifter bore question [Re: AndyF] #913821
01/26/11 11:41 PM
01/26/11 11:41 PM
NORTHERN CA
NORTHERN CA
Thanks, guys/ An old timer said I didn't need them with that cam, but didn't say anything about pushrod oiling. Mike
Re: Solid lifter/bushed lifter bore question [Re: HUSTLESTUFF] #913822
01/27/11 03:16 AM
01/27/11 03:16 AM
AndyF Offline
AndyF  Offline
Well he is correct, you don't need them for that cam. Then again, a year from now you might want to change cams. Pays to think ahead sometimes.
Re: Solid lifter/bushed lifter bore question [Re: HUSTLESTUFF] #913823
01/27/11 04:00 AM
01/27/11 04:00 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
If you think you might want to run an EDM lifter (I wouldn't run a solid cam again without them) in the future it would be nice to have the oil hole. The EDMs also oil through the pushrod.
