Name that Part! - 70 'Cuda #913488
01/25/11 05:38 AM
01/25/11 05:38 AM
Northeast
edl Offline OP
edl  Offline OP
Northeast
hello - can you pls help identify the parts below - off of a 70 cuda (supposedly) that is in boxes in my garage - thanks!
Re: brackets - 70 cuda [Re: edl] #913489
01/25/11 07:34 AM
01/25/11 07:34 AM
Austria
3eighty3 Offline
3eighty3  Offline
Austria
I believe the brackets tie the top of the fenderes to the cowl.
__________________________________
Cuda blog
Re: brackets - 70 cuda [Re: 3eighty3] #913490
01/25/11 08:33 AM
01/25/11 08:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Cuda blog
they are located just above the upper door hinge on each side of the cowl area to bolt the fender upper top/rear corner
Re: brackets - 70 cuda [Re: DAYCLONA] #913491
01/26/11 09:47 AM
01/26/11 09:47 AM
Northeast
edl Offline OP
edl  Offline OP
Northeast
thanks!
Re: Name that Part! - 70 'Cuda [Re: edl] #913492
02/21/11 09:58 AM
02/21/11 09:58 AM
Northeast
edl Offline OP
edl  Offline OP
Northeast
1. less a part than an option: is undercoating something that would be indicated on the fender tag? - if not, and if no build sheet or other docs exist, is it simply my choice as to underbody (paint v. undercoating) and it would still be correct?
2. Hood: another slightly off topic question - was it painted undersides the same colar as body or somethint else
3. Trunk Paint: what is correct speckle paint?
thanks!
Re: Name that Part! - 70 'Cuda [Re: edl] #913493
02/21/11 11:57 AM
02/21/11 11:57 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
1) You should see evidence of undercoating on the bottom of car if it was undercoated from the factory.
1a) Bottom of car should be gray primer color with primary color overspray on bottom. Hopefully someone will post a few photos for you.
2) Bottom of hood is body color.
3) Mopar did not use speckle paint for trunks on 1970 e bodies. Your trunk will be body color.
Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Name that Part! - 70 'Cuda [Re: 70gtx440dana] #913494
02/21/11 02:51 PM
02/21/11 02:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Name that Part! - 70 'Cuda [Re: edl] #913495
02/21/11 04:42 PM
02/21/11 04:42 PM
IMGTX Offline
IMGTX  Offline
A note on undercoating. All cars had undercoating in the inner fenders to prevent rocks from dinging the underside of the fender. If it had the optional undercoating it would have undercoating on the floorboards & gastank. Correct?
Re: Name that Part! - 70 'Cuda [Re: IMGTX] #913496
02/21/11 09:03 PM
02/21/11 09:03 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
You are correct...
