jets size for my 440? #912953
01/24/11 04:54 PM
01/24/11 04:54 PM
United states wisconsin
bigblockbryan Offline OP
okay last summer i battled with my timing and it wasnt that now heres my deal i bought a 484 comp cam for my 440 running 10.1 comp with 346 heads with a stock outta the box elderbrock performer 750 carb what size jets should i be using with with this cam i also have a performer intake a dual plain mopar electroic ignition i think im gonna go buy a zip kit this friday dont now when ill start on the mighty fury battle again but my muscle car bug is starting to bite again
Re: jets size for my 440? [Re: bigblockbryan] #912954
01/24/11 06:37 PM
01/24/11 06:37 PM
I'd think the performer 750 would be jetted fairly rich out of the box. refresh us on the symptoms.
Re: jets size for my 440? [Re: RapidRobert] #912955
01/24/11 06:44 PM
01/24/11 06:44 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Your combo is fairly close to one I had a while back, and I was running the Eddy carb - got rid of it after months of trying and went with the Mighty Demon 750. Right off, it solved most of the problems I was having.
'71 SSP - SOLD!
Re: jets size for my 440? [Re: Mobarge] #912956
01/24/11 06:53 PM
01/24/11 06:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't say that the carterbrock faithful will hear you.
That said, buy the jet kit and have a go at it. I think they are shipped with almost the biggest rods. Make sure the floats are set well and yo have no more than 7psi of fuel pressure. Then tune it with a good vacuum gauge. Also you timing should be set beofre you try and adjust the carb.
Coming soon!!!!
Re: jets size for my 440? [Re: Mr.Yuck] #912957
01/24/11 08:34 PM
01/24/11 08:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is one case where your standard get a holley and never look back ... would be a welcome response , the performer 750 is a piece of junk .
Re: jets size for my 440? [Re: JohnRR] #912958
01/24/11 09:28 PM
01/24/11 09:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what???
Coming soon!!!!
Re: jets size for my 440? [Re: RapidRobert] #912959
01/25/11 04:20 PM
01/25/11 04:20 PM
well it would run really good not under load then as soon as there was load it would start to miss bad at peak rpm and i timed the be jeus outta that motor last summer im actually thinking about pulling the motor next month and just having it dyno tuned but on the other hand would like to now what im doing for my next build too
Re: jets size for my 440? [Re: bigblockbryan] #912960
01/25/11 04:26 PM
01/25/11 04:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
might not be a carb problem, have you checked your volts at the coil? I had a balast go bad and guess what ot would start run fine as soon as you dropped it into gear it would flutter and die...just a thought.
Re: jets size for my 440? [Re: Mr.Yuck] #912961
01/25/11 04:30 PM
01/25/11 04:30 PM
yea i believe i checked it i will keep it in mind come spring furys under 2 feet of snow maybe ill go buy a new coil i have had the same one on it since 2003 i got ballast resister up the tail but im pretty sure changed that around
Re: jets size for my 440? [Re: bigblockbryan] #912962
01/25/11 09:01 PM
01/25/11 09:01 PM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
How old are the spark plug wires & what brand are they?
69 Charger RT
Re: jets size for my 440? [Re: greenpigs] #912963
01/26/11 05:08 AM
01/26/11 05:08 AM
theyre acell 3-4 years old never had a single problem with this engine untill i put this 484 cam in. I had a resto mod cam before then what happened was i had a bad fuel pump that leaked gas into the block wrecking the bearings and the cam so i decied when i replacd everything to up the cam in it to the 484
Re: jets size for my 440? [Re: bigblockbryan] #912964
01/26/11 07:34 AM
01/26/11 07:34 AM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
I have not heard good things about those wires. Even if you don't think they are a problem I would check them for ohms resistence...you may be suprised. 150 ohms per foot is the MOST I would let slide. Firecore50's are yep 50 ohms per foot and worth the coin if you find your current wires suck.
69 Charger RT
