Re: jets size for my 440?
[Re: bigblockbryan]
#912954
01/24/11 06:37 PM
01/24/11 06:37 PM
RapidRobert
I'd think the performer 750 would be jetted fairly rich out of the box. refresh us on the symptoms.
[Re: RapidRobert]
#912955
01/24/11 06:44 PM
01/24/11 06:44 PM
Posts: 1,213 Los Angeles, CA
Mobarge
Los Angeles, CA
Your combo is fairly close to one I had a while back, and I was running the Eddy carb - got rid of it after months of trying and went with the Mighty Demon 750. Right off, it solved most of the problems I was having.
'71 SSP - SOLD!
[Re: Mobarge]
#912956
01/24/11 06:53 PM
01/24/11 06:53 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
don't say that the carterbrock faithful will hear you. That said, buy the jet kit and have a go at it. I think they are shipped with almost the biggest rods. Make sure the floats are set well and yo have no more than 7psi of fuel pressure. Then tune it with a good vacuum gauge. Also you timing should be set beofre you try and adjust the carb.
[Re: Mr.Yuck]
#912957
01/24/11 08:34 PM
01/24/11 08:34 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
This is one case where your standard get a holley and never look back ... would be a welcome response , the performer 750 is a piece of junk .
[Re: JohnRR]
#912958
01/24/11 09:28 PM
01/24/11 09:28 PM
Mr.Yuck
Brookeville, Md
what???
