Re: slave cylinder on the A833
[Re: dangina]
#909287
01/20/11 07:45 PM
01/20/11 07:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Bigblockdart.com used to have a page one how to make a bracket that would allow an early Dodge truck slave cylinder to operate the clutch fork on an A833. Link is now broken.
[Re: OzHemi]
#909293
01/21/11 08:44 PM
01/21/11 08:44 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Cool idea
Thanks. What I learned about hydraulic clutching over the last 9 mo. has been eye-opening. At first it was: "no way would I ever go hydraulic (the purist in me), but I'll research it anyway" to: "Why didn't I do this from Day 1(another neurosis torpedoed)"
[Re: rabid scott]
#909294
01/21/11 08:52 PM
01/21/11 08:52 PM
Commando1
Did you have any problems bleeding it out since the bleeder is on the bottom?
You notice that the one I gave you the link to has the bleeder screw on top. That's the correct no.
Mine with the bleeder on the bottom wasn't a problem though. There's really no chamber for air to really get trapped.
The beauty about this 20 dollar gem is even if you run an old style big clunky starter, it will fit.
[Re: DrCharles]
#909297
01/22/11 10:50 AM
01/22/11 10:50 AM
Commando1
There's only one more variable to be worried about: Does it have enough stroke?
It has MORE than enough throw. In fact, you have to install a clutch pedal stop to limit travel. I drilled a hole in the floor (in line with the clutch pedal arm, of course), welded a 5/8" nut to it, and threaded in a 5/8 bolt and double nutted it at the correct throw distance. It's adjustable that way.
[Re: Kern Dog]
#909298
01/22/11 11:10 AM
01/22/11 11:10 AM
Commando1
This is fantastic.... Now how do you get the other end to work? What do you do for the pedal to clutch/master cylinder unit? More info please!
For the hydraulic clutch master cylinder I used this one (mounted directly to the firewall) from AutoZone for 30 bucks: http://www.autozone.com/autozone/parts/D...ier=133597_0_0_
So, you're now in for under fifty bucks and they have a lifetime replacement warrantee.
I simply attached the rod to the clutch pedal with a shortened hitch pin.
[Re: Commando1]
#909299
01/22/11 11:23 AM
01/22/11 11:23 AM
Commando1
I want to amend this whole thing with one point. The setup worked flawlessly except in my case my fork bracket and fork bracket mount turned out to be too worn. I was about to buy new ones when I said W.T.eff, I'm going to go for the whole enchilada and try a hydraulic throw out bearing from Tilton (through Summit). The bearing arrived in two days. The bearing to transmission mount is back ordered until mid Feb. So, for that part of the overall project, I'm on hold for a month.
