{{{ Tunnel Ram Vacuum Question }}}
#906880
01/16/11 10:09 PM
01/16/11 10:09 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
OK....can I tap directly into the tunnel ram plenum for the PCV Valve or is it better to go to the carb or should I be pulling from both carbs t'd to the pcv....????? The reson is it would be a clean direct route from the t-ram to the pcv Rickster
Re: {{{ Tunnel Ram Vacuum Question }}}
[Re: rickstershemi]
#906881
01/16/11 10:15 PM
01/16/11 10:15 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
either place is fine, whatever looks cleaner would be the best route. me persoanly would drill and tap under the plenum to hide it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: rickstershemi]
#906882
01/16/11 10:18 PM
01/16/11 10:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Rickster
Its all the same vac under the throttle blades... put it anywhere that looks good
[Re: MR_P_BODY]
#906883
01/16/11 10:20 PM
01/16/11 10:20 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Vacuum hoses are ugly. I'd tap the rear of the plenum to keep the hose as out of sight as possible.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: bigtimeauto]
#906884
01/16/11 10:22 PM
01/16/11 10:22 PM
rickstershemi
Kinda what I thought...and under the plenum sounds like a good idea.....Thanks
Rickster
[Re: sixpackgut]
#906887
01/16/11 11:41 PM
01/16/11 11:41 PM
Quicktree
i wouldnt run a PVC
me neither, isn'6t that something plumbers use
