Re: bigger rear drums on an A body
[Re: babarracuda]
#906551
01/16/11 03:56 PM
01/16/11 03:56 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
the drums I am running on my 76 dart are 11 x 2-3/4 Inch Brakes. However I do have to go to 15" rims because the 14" Ralleys are just too tight on there.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: babarracuda]
#906553
01/16/11 04:08 PM
01/16/11 04:08 PM
blk00rt
Michigan Troll
the ones I use are for a 1966 Dodge Polara V8 - 6.3L 383ci
[Re: babarracuda]
#906554
01/16/11 04:10 PM
01/16/11 04:10 PM
RapidRobert
big or small pattern? I'd always thought that the std 1&3/4" SBP ones were it unless you went BBP. There was something way back about the 7&1/4 backing plate/drum that could be swapped for more shoe width that Mark Nixon came up w (& it think it made the archives) but not sure if it was sbp or bbp & it was too far back.
[Re: west]
#906557
01/16/11 04:35 PM
01/16/11 04:35 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ted...
you can put 11 x 3 drum on the rear as long as you get the backing plates to go with them.
That is what i have on my 69 Barracuda.
I got those off a 78 Dodge Magnum or Monaco..I think...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: babarracuda]
#906559
01/16/11 08:39 PM
01/16/11 08:39 PM
Posts: 15,487 Florida
scratchnfotraction
the stock A-body has its own axle offset and backing plates for 1 3/4" brakes with sbp
if it has been a narrowed housing and you have the large brake off set on the axle you can use any BP-drums from
8 1/4 8 3/4 9 1/4 d-60
i used 73 newport BP-drums 11x2.5 on my narrowed a-body 8 3/4 with large brake offset axles
just get BP and brake hardware from any spare axle of your size and like
I ran 12 disc(R-body cop car) on 73 a-body spindles with 11x2.5 rear brakes on my 68 Dart with the 2-bolt alum MC
stoped real fast and no locking up
