bigger rear drums on an A body #906550
01/16/11 03:51 PM
01/16/11 03:51 PM
Carson City, NV
babarracuda Offline OP
Carson City, NV
What is the biggest rear brake drum thatI can put on my 67 A body without changing axels? I have an 8 3/4 that's been shortened
Re: bigger rear drums on an A body [Re: babarracuda] #906551
01/16/11 03:56 PM
01/16/11 03:56 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the drums I am running on my 76 dart are 11 x 2-3/4 Inch Brakes. However I do have to go to 15" rims because the 14" Ralleys are just too tight on there.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: bigger rear drums on an A body [Re: blk00rt] #906552
01/16/11 04:01 PM
01/16/11 04:01 PM
Carson City, NV
Carson City, NV
Where did you get them? From what model car?
Re: bigger rear drums on an A body [Re: babarracuda] #906553
01/16/11 04:08 PM
01/16/11 04:08 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the ones I use are for a 1966 Dodge Polara V8 - 6.3L 383ci
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: bigger rear drums on an A body [Re: babarracuda] #906554
01/16/11 04:10 PM
01/16/11 04:10 PM
big or small pattern? I'd always thought that the std 1&3/4" SBP ones were it unless you went BBP. There was something way back about the 7&1/4 backing plate/drum that could be swapped for more shoe width that Mark Nixon came up w (& it think it made the archives) but not sure if it was sbp or bbp & it was too far back.
Re: bigger rear drums on an A body [Re: RapidRobert] #906555
01/16/11 04:22 PM
01/16/11 04:22 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
bbp is what I am running
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: bigger rear drums on an A body [Re: blk00rt] #906556
01/16/11 04:28 PM
01/16/11 04:28 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
just drill the holes out in the drums to accommodate what you have.plenty of meat there to work with.
Re: bigger rear drums on an A body [Re: west] #906557
01/16/11 04:35 PM
01/16/11 04:35 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Ted...
you can put 11 x 3 drum on the rear as long as you get the backing plates to go with them.
That is what i have on my 69 Barracuda.
I got those off a 78 Dodge Magnum or Monaco..I think...
Tony
70 AARCuda Vitamin C
Re: bigger rear drums on an A body [Re: 70AARcuda] #906558
01/16/11 05:33 PM
01/16/11 05:33 PM
Carson City, NV
Carson City, NV
Thanks Tony, I have 5/4.5 bolt pattern
Re: bigger rear drums on an A body [Re: babarracuda] #906559
01/16/11 08:39 PM
01/16/11 08:39 PM
scratchnfotraction Offline
the stock A-body has its own axle offset and backing plates for 1 3/4" brakes with sbp
if it has been a narrowed housing and you have the large brake off set on the axle you can use any BP-drums from
8 1/4
8 3/4
9 1/4
d-60
i used 73 newport BP-drums 11x2.5 on my narrowed a-body 8 3/4 with large brake offset axles
just get BP and brake hardware from any spare axle of your size and like
I ran 12 disc(R-body cop car) on 73 a-body spindles with 11x2.5 rear brakes on my 68 Dart with the 2-bolt alum MC
stoped real fast and no locking up
