pertronix ready to run distributor? #905486
01/15/11 04:49 PM
01/15/11 04:49 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Anyone running the Pertronix ready to run distributor? Any issues? I like the idea of not having to mount an ignition box but haven't heard much about these. Any opinions? http://www.summitracing.com/parts/PNX-D7142800/ Thanks
Re: pertronix ready to run distributor? [Re: 440forPOWER] #905487
01/15/11 04:57 PM
01/15/11 04:57 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I have always just removed the points and stuck in the Petronix module as it's so easy even i can do it. I would think the readymade unit would only be needed if you do not have an exising distributer maybe??
Re: pertronix ready to run distributor? [Re: MidPenMopar] #905488
01/15/11 05:06 PM
01/15/11 05:06 PM
Lincoln NE
super gas
super gas
Lincoln NE
Hello, Yeah I need a distributor anyway. Have you ever had any problems with them?
Re: pertronix ready to run distributor? [Re: 440forPOWER] #905489
01/15/11 05:26 PM
01/15/11 05:26 PM
MidPenMopar Offline
MidPenMopar  Offline
Never but then i always carry an extra one just in case!
Re: pertronix ready to run distributor? [Re: MidPenMopar] #905490
01/15/11 05:36 PM
01/15/11 05:36 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
ive removed a few fom customer cars and gone with msd...i had one in my mustang and it broke up over 4grand...ok for a put put driver but in a performance ap id go msd
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: pertronix ready to run distributor? [Re: pnypwr] #905491
01/15/11 07:32 PM
01/15/11 07:32 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
It should have the Pertronix Ignitor III module in it, which features double strike 40-45KV, rev limiter all under the cap.
I've played with the module (phasing was bad) but not their distributor.
Re: pertronix ready to run distributor? [Re: six-barrel] #905492
01/15/11 08:25 PM
01/15/11 08:25 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
Never used their distributor but many of their kits. I and II.
The next I buy will be the III. Now this is just my experience but have run the I in two different cars on the track and both took 6 grand shifts no problem. With the II you by-pass the ballast but must upgrade the coil to a 0.6 ohm.The III works with a .032 ohm coil.
I didn't change the coil on the first II and the car ran like crap. The old saying "when all else fails read the directions" did apply that time. I too carried a spair but in 10+years none have failed. So I guess the quality of their distributor should be as high.
