How much oil to put in motor? #90493
07/18/08 08:30 PM
07/18/08 08:30 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
OK guys, if you put a Milidon "7 quart" pan on your RB motor, add 7 quarts of oil and your universal dipstick from 440 source says you're still 1.5 to 2 quarts low, do you add more oil to reach the "full" mark on the stick or remark the stick?
Re: How much oil to put in motor? [Re: Ramrod39] #90494
07/18/08 09:06 PM
07/18/08 09:06 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
A 7 qrt pan + the filter will need 8 qrts, correct?
Re: How much oil to put in motor? [Re: Ramrod39] #90495
07/18/08 10:16 PM
07/18/08 10:16 PM
7 quarts in the pan, + .5-.75 for the filter, scribe a mark on your
super accurate dipstick. done.
Re: How much oil to put in motor? [Re: Ramrod39] #90496
07/19/08 12:21 AM
07/19/08 12:21 AM
tucson az
frank Offline
frank  Offline
tucson az
Remark the stick
Re: How much oil to put in motor? [Re: frank] #90497
07/19/08 12:28 AM
07/19/08 12:28 AM
throw 7qts in pan,level surface,mark stick at that point,start car & level will decrease ~ 3/4 qt as filter fills.top off back to full mark.
Re: How much oil to put in motor? [Re: RapidRobert] #90498
07/19/08 01:43 AM
07/19/08 01:43 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Deep pans are to get oil away from the crankshaft, not for added capacity.
Re: How much oil to put in motor? [Re: Magnum] #90499
07/19/08 02:14 AM
07/19/08 02:14 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Put as little in as possible as long as the pickup never gets uncovered. 7 quarts in a 7QT pan is a waste. I'd try 5.5 to 6max.
