Re: 340 Steel Intake Gaskets - Where to Buy?
[Re: Kern Dog]
#904835
01/15/11 07:20 AM
01/15/11 07:20 AM
Posts: 636 California
sixpaktoogo
California
The Fel Pro set in a box usually has the thin steel gaskets inside as well as the blue composite ones.
Not any more! Same with Victor.
[Re: 68GTS383]
#904839
01/15/11 11:26 AM
01/15/11 11:26 AM
Posts: 15,487 Florida
scratchnfotraction
just you JK yep I have only seen them for small port 318s myself I use a fel-pro #1213 with heat block off,IIRC victor gasket set was the last time I saw any,been a while i run 360 heads most times anyways,only when swaping a 2-v to 4-v do I run the 318 heads but I am running a small port LD4B on large port heads
[Re: scratchnfotraction]
#904841
01/15/11 01:01 PM
01/15/11 01:01 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Ran this combo myself for a few years and ran in the 11.90's -12.0 with it. No gasket matching or anything. Alwaysed Used the large port composite gaskets for a better sealing surface with no problems. The tin ones have minimal sealing surface.
[Re: mopars4ever]
#904842
01/15/11 01:25 PM
01/15/11 01:25 PM
sixpaktoogo
California
The 340 came with paper/composite gaskets from the factory. I don`t think mopar ever offered them in steel except for the 318. Why? Who knows? May I ask why are you looking for steel gaskets? There are much better choices out there now. The mopar part number for the gasket in 1973 is 3514187 and for 70-71 2808689. Brads nos has the latter.
I have two 340 engines. One 68, and one 70. Both were never apart, and both had steel gaskets with McCord part numbers on them. The 318 (2 barrel) versions are available (small port). The composite gasket sticks up past the manifold, and in a OE restoration, as I am doing, looks terrible, and is incorrect.
[Re: sixpaktoogo]
#904843
01/15/11 02:50 PM
01/15/11 02:50 PM
MoparforLife
Upper Midwest
So is the LD4B intake. It was Never OEM
[Re: MoparforLife]
#904844
01/15/11 05:04 PM
01/15/11 05:04 PM
sixpaktoogo
California
Can't understand your response to my last statement. I believe your comment is in response to the member that stated he is using a LD4B, which I am not.
[Re: sixpaktoogo]
#904845
01/15/11 06:03 PM
01/15/11 06:03 PM
MoparforLife
Upper Midwest
You are right- I am sorry. Please accept my apology.
[Re: Gt383]
#904847
01/15/11 08:19 PM
01/15/11 08:19 PM
Posts: 13,601 md
mopars4ever
md
The part number 2808689 most likely is the part you need but Brads is going want a lot for them. Not worth it for something you won`t see as not all the gaskets available for the 340 stick up above the intake. I would not chance steel ones for sealing anyways. Oh well it`s your car and money so do what you wish. Just trying to help.
[Re: mopars4ever]
#904848
01/15/11 11:58 PM
01/15/11 11:58 PM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
Maybe you could mark and trim the composite gasket so it doesn't protrude past the intake before you install it. Or if the 318 steel gaskets have enough meat maybe take a die grinder and do a port match and use them. Just a couple of "if all else fails" options.
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
[Re: 68GTS383]
#904849
01/16/11 06:53 AM
01/16/11 06:53 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I called my local Napa yesterday looking for 318 valve cover gaskets and his first question: is it two or four wheel drive? Does that piss anyone else off or is it just me?
NO, It is NOT just you. This is the symptom of an IDIOT counterman. Smart and experienced people know that in many cases, ALL roads will lead back to the same part and they will NOT ask stupid questions like..... Customer: Hey... I need a upper radiator hose for a 74 Dodge 3/4 ton 2 wd with a 440. Idiot: 2 door? Customer: Uhhh, yeah. Idiot: Regular cab? Customer: Uhhh, sure. Idiot: Air Conditioning? Customer: No. Idiot: Power steering? Customer: Yes, but why does tha... Idiot: Automatic or manual? Customer: It doesnt matter. Idiot stares at customer until customer responds with... Customer: Auto Idiot: Am/Fm? Customer: Now come on, I only need a radiator ho....... Idiot: I dont have it in stock, its in our warehouse in Usuckestan. I can have it here thursday.....
