Edelbrock Performer intake coil mount ??? #904336
01/14/11 12:42 PM
01/14/11 12:42 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
I have an Edelbrock Performer (NOT RPM) on my 440. Where have you guys mounted the coil? There doesn't seem to be a spot for the stock coil bracket. Was thinking about using a 6 pack coil bracket.
Any suggestions?
Scott
1969 Super Bee, 383/4 speed
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904337
01/14/11 01:07 PM
01/14/11 01:07 PM
Louisiana
duckblind Offline
duckblind  Offline
Louisiana
here is a picture of mine.
Re: Edelbrock Performer intake coil mount ??? [Re: duckblind] #904338
01/14/11 01:14 PM
01/14/11 01:14 PM
Northern NJ
Northern NJ
Thanks, but mine does not have those same mounting bosses.
Scott
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904339
01/14/11 01:37 PM
01/14/11 01:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Most of the 6 pack style coil brackets I've sold were for this very reason.
mostly non stock applications like this
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904340
01/14/11 02:15 PM
01/14/11 02:15 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Yea you do! I's right there to the left in front of the carb.
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904341
01/14/11 03:55 PM
01/14/11 03:55 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Have you considered mounting your coil away from the motor since you don't have a specific bracket for that intake?
This method would keep your coil running cooler and you could use the 6-pac bracket and maybe fab up a second bracket and hang it elsewhere using a longer coil wire.
Re: Edelbrock Performer intake coil mount ??? [Re: stubbs300 ] #904342
01/14/11 05:35 PM
01/14/11 05:35 PM
scratchnfotraction Offline
thats them to the pass side of front intake runner
my stock intakes is same place
and the weiand action plus I have is same place
on my sb I just used some cut up thottle brackets with a sigle hole coil strap welded on,bolts on 1 intake bolt sticks up-curves back and coil is held horozontal inbetween the VC and carb
use a one hole coil strap in the 1 front hole and it should fit fine
always can mount on the firewall where the heater fan used to be..maybe the fender well
Re: Edelbrock Performer intake coil mount ??? [Re: scratchnfotraction] #904343
01/14/11 06:42 PM
01/14/11 06:42 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Mine. Eddy performer. Mounts are there.
Re: Edelbrock Performer intake coil mount ??? [Re: Dougsmopars] #904344
01/14/11 06:50 PM
01/14/11 06:50 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The problem with the mounts is that they are designed for an AFB/AVS style carb. Running a dual feed Holley you're not getting the coil on there. I decided to use one of the holes (the one furthest from the carb) and use a Ford Windsor coil bracket, which only has one mounting hole and the bracket wraps around the coil.
Re: Edelbrock Performer intake coil mount ??? [Re: GTX MATT] #904345
01/14/11 07:24 PM
01/14/11 07:24 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have the CH28 (Dual Quad) I have the MSD coil. I was forced to mount it upright because of a leakage issue with the Blaster II coils. I got a Mr Gasket special with the chrome brackets and the sleeve. Both ears are mounted on the valley pan hold down plates...In direct line with the fan blowing on it....add insult to injury, its even stuffed under a Six-Pack type air cleaner...It might get a little hot in its current position....I didn't have an alternative. I dont want a coil wire running to the fender or the firewall.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Edelbrock Performer intake coil mount ??? [Re: stubbs300 ] #904346
01/14/11 10:34 PM
01/14/11 10:34 PM
Northern NJ
Northern NJ
I know, but the bosses are 2 different heights. I was also thinking of using the Ford single bolt mount on the front boss.
Scott
Re: Edelbrock Performer intake coil mount ??? [Re: Pyper70] #904347
01/14/11 10:36 PM
01/14/11 10:36 PM
Northern NJ
Northern NJ
Neither do I. I will make it work. I also have the MSD Leaker2 coil. I gotta get rid of that thing. Is there a good, leak free alternative that mounts in a stock type bracket?
Scott
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904348
01/14/11 10:38 PM
01/14/11 10:38 PM
let me look in the shed,a sb 2 hole coil strap has the 2 flanges offset
may work out for what you need in offset to mount it
may have a spare 1 hole coil strap as well
what the ehll are you saying???? come this far and gonna put ferd parts on it???
thats just not right...just not right at all
chebby carb maybe but ferd..you gots to be kidding me
I would use amc or something
plez stop with the ferd parts on it would ya
Re: Edelbrock Performer intake coil mount ??? [Re: scratchnfotraction] #904349
01/14/11 10:42 PM
01/14/11 10:42 PM
Northern NJ
Northern NJ
Scratch, you are too much. I did not forget you. I am putting a small care package together for you. Just waiting for a couple items from work.
Scott
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904350
01/14/11 11:58 PM
01/14/11 11:58 PM
AndyF Online content
AndyF  Online Content
Hughes Engines has several different coil mounts that will work.
Re: Edelbrock Performer intake coil mount ??? [Re: AndyF] #904351
01/15/11 12:50 AM
01/15/11 12:50 AM
okla.
sam64 Offline
sam64  Offline
okla.
is it me or is that intake on backwards? shouldn't that egr plate be on the pass side.
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904352
01/15/11 01:29 AM
01/15/11 01:29 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
An oil filled coil will be happiest/live longest mounted on the firewall or fender. Heat is their enemy. Would a later model OE Magnum series engine type (non oil filled coil) work on a big block?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Edelbrock Performer intake coil mount ??? [Re: GO_Fish] #904353
01/15/11 08:29 AM
01/15/11 08:29 AM
thats kool,just dont use any ferd parts on it....bad mojo..bad juju..you might get ninjerd cause of it when it mis fires
I will be gettin one of the big old skool accel coils for the mallory duel points dist for mine that will go on the inner fender of my truck to clean the looks of the engine up some
coil does not care how long the coil wire is it will go with the other real long plug wires it has
you can see the small accel coil on it in the sig pic and with the new alum intake
Re: Edelbrock Performer intake coil mount ??? [Re: sam64] #904354
01/15/11 02:19 PM
01/15/11 02:19 PM
Elwood Ne.
64B Body Offline
64B Body  Offline
Elwood Ne.
I agree with sam i believe you have it on backwards
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904355
01/15/11 03:46 PM
01/15/11 03:46 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
MSD has an epoxy filled blaster coil that looks just like the oil filled ones.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
