Edelbrock Performer intake coil mount ???
#904336
01/14/11 12:42 PM
01/14/11 12:42 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I have an Edelbrock Performer (NOT RPM) on my 440. Where have you guys mounted the coil? There doesn't seem to be a spot for the stock coil bracket. Was thinking about using a 6 pack coil bracket. Any suggestions?
Scott
1969 Super Bee, 383/4 speed
Re: Edelbrock Performer intake coil mount ???
[Re: StukaJU87]
#904341
01/14/11 03:55 PM
01/14/11 03:55 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Have you considered mounting your coil away from the motor since you don't have a specific bracket for that intake? This method would keep your coil running cooler and you could use the 6-pac bracket and maybe fab up a second bracket and hang it elsewhere using a longer coil wire.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: stubbs300 ]
#904342
01/14/11 05:35 PM
01/14/11 05:35 PM
Posts: 15,487 Florida
scratchnfotraction
thats them to the pass side of front intake runner my stock intakes is same place and the weiand action plus I have is same place on my sb I just used some cut up thottle brackets with a sigle hole coil strap welded on,bolts on 1 intake bolt sticks up-curves back and coil is held horozontal inbetween the VC and carb use a one hole coil strap in the 1 front hole and it should fit fine always can mount on the firewall where the heater fan used to be..maybe the fender well
[Re: Dougsmopars]
#904344
01/14/11 06:50 PM
01/14/11 06:50 PM
Posts: 5,161 CT
GTX MATT
CT
The problem with the mounts is that they are designed for an AFB/AVS style carb. Running a dual feed Holley you're not getting the coil on there. I decided to use one of the holes (the one furthest from the carb) and use a Ford Windsor coil bracket, which only has one mounting hole and the bracket wraps around the coil.
[Re: GTX MATT]
#904345
01/14/11 07:24 PM
01/14/11 07:24 PM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
I have the CH28 (Dual Quad) I have the MSD coil. I was forced to mount it upright because of a leakage issue with the Blaster II coils. I got a Mr Gasket special with the chrome brackets and the sleeve. Both ears are mounted on the valley pan hold down plates...In direct line with the fan blowing on it....add insult to injury, its even stuffed under a Six-Pack type air cleaner...It might get a little hot in its current position....I didn't have an alternative. I dont want a coil wire running to the fender or the firewall.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: StukaJU87]
#904348
01/14/11 10:38 PM
01/14/11 10:38 PM
scratchnfotraction
let me look in the shed,a sb 2 hole coil strap has the 2 flanges offset may work out for what you need in offset to mount it may have a spare 1 hole coil strap as well what the ehll are you saying???? come this far and gonna put ferd parts on it??? thats just not right...just not right at all chebby carb maybe but ferd..you gots to be kidding me I would use amc or something plez stop with the ferd parts on it would ya
[Re: GO_Fish]
#904353
01/15/11 08:29 AM
01/15/11 08:29 AM
scratchnfotraction
thats kool,just dont use any ferd parts on it....bad mojo..bad juju..you might get ninjerd cause of it when it mis fires I will be gettin one of the big old skool accel coils for the mallory duel points dist for mine that will go on the inner fender of my truck to clean the looks of the engine up some coil does not care how long the coil wire is it will go with the other real long plug wires it has you can see the small accel coil on it in the sig pic and with the new alum intake
[Re: StukaJU87]
#904355
01/15/11 03:46 PM
01/15/11 03:46 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Neither do I. I will make it work. I also have the MSD Leaker2 coil. I gotta get rid of that thing. Is there a good, leak free alternative that mounts in a stock type bracket?
MSD has an epoxy filled blaster coil that looks just like the oil filled ones.
