Cubic inches- vs- Boost?
#903765
01/13/11 05:27 PM
01/13/11 05:27 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Power and driveability wise what would be more feasable? I have a 383 in the car now and am putting a B&M 174 Supercharger on it. But it has 9.25 comp. in it now w/KB pistons. 9.25 is too much so short of cutting on the pistons,OR custom pistons I may end up with a decision. However I have TEN 440`s and a couple would only need freshened to be ready for what I want to do and they would already be low-comp, and also the piston choices for 440`s are many. 440 with say 5--6lbs. boost OR 383 with 8--10lbs. of boost? What would make more power all else being equal?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Cubic inches- vs- Boost?
[Re: TheOtherDodge]
#903767
01/13/11 07:47 PM
01/13/11 07:47 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I'd go with the 440 with 5 lbs. boost. But, you'll have to get a different blower manifold for the 440.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: 6bblFLASH]
#903769
01/13/11 09:05 PM
01/13/11 09:05 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
I have both B and RB intakes for the blower. I "assumed" more cubes would work as well but, was throwing it out there for those with more experience on this stuff
[Re: blownzoom440]
#903770
01/13/11 11:12 PM
01/13/11 11:12 PM
DaytonaTurbo
Manitoba, Canada
That's a bit small of a blower for a 440. It's displacement would be better suited for a 383. IIRC, a blower like that, pushed to its limit would only be able to make 5 or so pounds of boost on a 440. Really if all things were equal between the two, so same supercharger gearing ratios, same heads, cam, exhaust, etc I bet they would both perform similarly on the 1/4 mile.
[Re: Sport440]
#903772
01/14/11 01:34 PM
01/14/11 01:34 PM
Posts: 2,256 IL
furious70
IL
Did you buy the setup on here out of Chicago?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Sport440]
#903773
01/14/11 02:54 PM
01/14/11 02:54 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Both engines would have great driveability.
Hands down I would pick the bigger 440 motor. Less Boost = less Problems.
But the 383 with double the boost would make even more power then the 440 at half the boost.IMO mike
I don't know if the 383 could make double the boost w/ that small blower. Boost is really just a measure of resistance. It's more about getting the air/fuel into the chamber. For example a stockish 440 w/ unported heads, exhaust manis and 2.5 exhuast might show 6psi of boost, however a ported aluminum headed 440, w/ RPM intake, big tube headers and nice 3" exhaust would show 3-4. Same amount of air is being pushed by the same unit, however the stockish 440 is more restrictive. That small 174 unit could feed a mild 440. FWIW my old stockish 440 ran 12.90 before boost and 12.0 after about 5.5lbs of boost. I'd think that a mild 440 w/ 5psi of boost would out perform a mild 383 w/ 8lbs.
