Anyone with MP 175k converter experience? #902265
01/11/11 08:47 PM
01/11/11 08:47 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
I bought one of these MP 175K torque converters a few years back and stuck it on a shelf.
I’m considering putting it in Mrs G-bob’s 64 fury vert.
Specs are 426”, 9.6:1, with ported stealth heads, performer RPM and 770 cfm vac sec street avenger carb. Cam is comp XE275HL, .525 lift, 231/237 @ .050, 110 LSA, 106 ICL. Cam’s installed 4 degrees advanced.
Combo made 459 hp @ 5500 and 485 ft lb at 4500.
We set up an 8 ¾ with a 2.94 sure-grip and it’ll have 28” TA radials on it. Meant to be a highway cruiser. Expecting sustained cruise rpms of 2400-2500 or so.
Wondering how loose this converter is. They never really published stall numbers on them. Any ideas on whether it will work ok in cruiser? Just wondering if there will be much (too much) slippage at cruise.
Planning to have it ready in time for a cruise up I-15 to MATS in April, although I've got a TON of work to do on it before then.
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902266
01/11/11 11:54 PM
01/11/11 11:54 PM
San Diego
formula S Offline
formula S  Offline
San Diego
I did use one on a 440 with a 284/484 114 LC purple shaft, with 3.23 gears and it seemed to work pretty good the car was a 68 charger
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902267
01/12/11 12:22 AM
01/12/11 12:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a formula to figure it out but I forget it...
you know your torque and with the formula you can
figure the stall based on the K factor
EDIT
here it is
K = rpm / sqrt( torque )
rpm = K * sqrt( torque )
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902268
01/12/11 12:22 AM
01/12/11 12:22 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I've got one in a 73 RR. Flashes about 2800 behind a very mild 9:1 400 with a 268 XE Comp. 2.76 gears. Drives fine in town and on the highway.
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902269
01/12/11 01:03 AM
01/12/11 01:03 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
My opinion is that it will feel too "loose" for a cruiser. I had one behind my 470 in a Cuda, and it felt mushy. I am use to a manual trans, so perhaps it is just an adjustment, but I expect rapid response to throttle input. However given the torque of the motor and the loose converter, goosing the throttle did nothing but increase RPMs (that is, it only slipped) until over 4K.
My experience is that the formula that Mr.P Body posted was pretty close, with that converter in my car stalling a little over 4K. I found it annoying to be cruising at highway speeds, and goose the throttle and have nothing but an RPM increase. You really had to go deep into the throttle to feel response in the seat of your pants.
That Fury is fairly heavy and your motor is making good torque. My guess is that you will have a similar experience, particularly with the highway gears.
That converter is better suited behind a more mild engine from my perspective.
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902270
01/12/11 04:37 PM
01/12/11 04:37 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Here is a little more info, it looks like 2400 to 2500 stall
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902271
01/12/11 05:11 PM
01/12/11 05:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that converter is no where near where it needs to be for that combo. will it run and drive, yes. will it give the best ET for the combo? No
Re: Anyone with MP 175k converter experience? [Re: Quicktree] #902272
01/12/11 05:24 PM
01/12/11 05:24 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Meant to be a highway cruiser. Expecting sustained cruise rpms of 2400-2500 or so. He never mentioned anything about ET. I do agree with you that if it were a car intened for the track it could use more converter and a bunch more gear
Re: Anyone with MP 175k converter experience? [Re: Quicktree] #902273
01/12/11 05:27 PM
01/12/11 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think its going to be way above 2500 but I didnt
do the formula on it
EDIT
should be close to 3850
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902274
01/12/11 07:14 PM
01/12/11 07:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've used 2. Both were behind mild 440 B-body cars. 3800+ lbs. One was behind a 12.0 car and ran perfect for man years. I have 3 friends that also run them in mid 12 second 440 B-bodys. Zero problems. They were a steal at $138 back in the day.
Coming soon!!!!
Re: Anyone with MP 175k converter experience? [Re: formula S] #902275
01/12/11 07:15 PM
01/12/11 07:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
this is the race section, not the highway cruise section
Re: Anyone with MP 175k converter experience? [Re: Mr.Yuck] #902276
01/12/11 07:28 PM
01/12/11 07:28 PM
organ
maximum entropy Offline
organ
my experience exactly, and when i was done with it, i sold it for $100.00!
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902277
01/12/11 10:54 PM
01/12/11 10:54 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Cam's too big or the ratio should be 3.55, IMO
8.30's @3400 lbs
Re: Anyone with MP 175k converter experience? [Re: Mike Swann] #902278
01/12/11 11:15 PM
01/12/11 11:15 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Works good behind my turbo 6. Got it used local for around $100. Nice street manners.
I can make it stall pretty much wherever I want by foot braking it.
Re: Anyone with MP 175k converter experience? [Re: Quicktree] #902279
01/12/11 11:48 PM
01/12/11 11:48 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Sorry for the cruiser in the race section question, but this is where I hang out and knew I'd get the best info.
Besides, Mrs G-bob takes great pictures of race cars and this car is for her.
We know the 2.94's are not going to be anywhere close to optimum for 1/4 or even 1/8 mile action, but I don't think this car will ever see a track.
It's a 64 fury convertible that I've been promising her for 3 years would be ready for MATS. As long as she can smoke the tires a little, and it cruises good, she'll be happy.
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902280
01/13/11 07:58 AM
01/13/11 07:58 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
wow! just checked out the fury on your site.
I love it!
Is that how it sits now, or is there more?
If there's more, post up!
Re: Anyone with MP 175k converter experience? [Re: G_bob] #902281
01/13/11 08:19 AM
01/13/11 08:19 AM
Q
Quicktree Offline
Quicktree  Offline
Q
not a problem Bob like I said it will work if you already have it. if not I would go with a good 10"street converter.
Re: Anyone with MP 175k converter experience? [Re: Quicktree] #902282
01/13/11 04:33 PM
01/13/11 04:33 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I used the 166k lockup for a 904 in my 5th in front of both a 998 and an A500. car had a mild 360, stock long block, home ported heads, headers, RPM air gap, and a 600 eddie. gears were 3.55's, tires 27", car weight ~3900lbs w/o driver. The 166k would brake stall to about 2300 or so, and flash to about 2800. worked real well in the car for the combo. was a bit of a sloppy converter, engaging/disengaging lockup would drop cruise RPM by about 400 RPM. I miss that unit. I took it out when I replaced the 360 with a roller cammed, magnum headed 318 because I discovered cracks in the converter hub.
assuming you'd be similar weight, but more torque and more gearing, I'd say a 166K will stall even higher than it did in my lower power/lower torque environment, so I'd say the 175k is going to feel way to loose and sloppy for this combo, and probably flash to ~3500+....
if you were looking for a cheap converter, I'd probably start out looking at a factory high stall unit, I've seen those advertised for about $110....
2017 Grand Cherokee Overland
