SHAKER FEET BOLTS #899386
01/08/11 11:54 AM
01/08/11 11:54 AM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Hello,
Could someone tell me the size of these bolts and where to source(s) correct OEM? Thank you in advance.
Ray
Re: SHAKER FEET BOLTS [Re: rayztoy] #899387
01/08/11 12:39 PM
01/08/11 12:39 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Ray
Original ones I've removed had this bolt, 7/16 head with an N on it and a 3/4 wide washer. It is 7/8 inch long
Frank Badalson carries shaker feet bolts but I am not sure what is on the head.
The other two in the picture are original grill screw ( S on head... 8 req'd )and original screw that secures rear of cold door to grills ( E on head...2 req'd)
All are black phosphate
Re: SHAKER FEET BOLTS [Re: mccannix] #899388
01/08/11 01:04 PM
01/08/11 01:04 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Terry,
Thanks for the info!
Ray
Re: SHAKER FEET BOLTS [Re: rayztoy] #899389
01/08/11 02:04 PM
01/08/11 02:04 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Hello,
Ray
I have a question regarding part "M" the actual foot piece. Is the bottom of the foot covered with that black "rubberized" coating (like valve cover tabs) or .... what is on there to protect the valve cover? Anyone know?
Re: SHAKER FEET BOLTS [Re: kidmopar] #899390
01/08/11 02:36 PM
01/08/11 02:36 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Yes the feet themselves are covered with black rubberized coating as you stated.
The area is shown the diagram provided by Ray.
I should add that I have also seen the same shaker foot bolt used with SEMA on the top
Re: SHAKER FEET BOLTS [Re: rayztoy] #899391
01/09/11 01:48 AM
01/09/11 01:48 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: SHAKER FEET BOLTS [Re: gtx6970] #899392
01/09/11 11:24 AM
01/09/11 11:24 AM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Bill,
Thank you for the pics!
Ray
