Duster power steering #898581
01/07/11 01:15 PM
01/07/11 01:15 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
I am putting power steering pump on my wifes 73 Duster, I have the correct small block brackets and using a Saginaw pump. I see where the top bolt attaches to the water pump. I not sure where the bottom bolt go's. Am I missing something, is there a bracket that comes off the side of the water pump and attaches to the power steering bracket. Thanks for any help.
Re: Duster power steering [Re: Moparmedic440] #898582
01/07/11 06:31 PM
01/07/11 06:31 PM
ohio
geol Offline
geol  Offline
ohio
HERE IS A PIC OF MY 69 340 WITH POWER STEERING.DON'T KNOW IF IT WILL HELP,BUT IT MAY.
Re: Duster power steering [Re: geol] #898583
01/07/11 06:41 PM
01/07/11 06:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No, that is for a cast iron 69 down water pump system with drivers side radiator hose inlet.
Off topic....Is your car petty unmolested? Is that the original battery ground cable. The large cylinder insulator at the head looks familar. Some 340's seem to have that ground strap and some do not.
Re: Duster power steering [Re: geol] #898584
01/07/11 07:05 PM
01/07/11 07:05 PM
ohio
geol Offline
geol  Offline
ohio
NOT SURE HOW UNMOLESTED THE MOTOR IS.I KNOW MY COUSIN TOOK IT OUT OF A 69 CUDA AND INSTALLED IT INTO THIS 72 DUSTER.THE MOTOR IS NOW BEING REBUILT IN THE MACHINE SHOP.IT WAS PRETTY TIRED INTERNALLY.
Re: Duster power steering [Re: Moparmedic440] #898585
01/08/11 02:41 AM
01/08/11 02:41 AM
West Central Wisconsin
Exciter72 Offline
Exciter72  Offline
Here are some pic's of the one I took off a 72' 340.
Re: Duster power steering [Re: Exciter72] #898586
01/08/11 02:41 AM
01/08/11 02:41 AM
Exciter72 Offline
Exciter72  Offline
Another
Re: Duster power steering [Re: Exciter72] #898587
01/08/11 02:46 AM
01/08/11 02:46 AM
Exciter72 Offline
Exciter72  Offline
last pic, hope they help.
Re: Duster power steering [Re: Moparmedic440] #898588
01/08/11 02:02 PM
01/08/11 02:02 PM
Clovis,NM
Dartman318 Offline
Dartman318  Offline
Clovis,NM
Here is a pic of my 1974 Duster 360 power steering brackets.
Hope that helps!
