pic's of torque straps #898190
01/06/11 10:52 PM
01/06/11 10:52 PM
Whitinsville Ma
superbee500 Offline OP
Whitinsville Ma
Thinking of fabricating a Torque strap for my Bee. I need some pics for ideas.
Kevin
69 superbee 04 ram 3500
Re: pic's of torque straps [Re: superbee500] #898191
01/06/11 10:55 PM
01/06/11 10:55 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Re: pic's of torque straps [Re: prochargedhemi] #898192
01/06/11 11:02 PM
01/06/11 11:02 PM
Whitinsville Ma
Whitinsville Ma
Nice but being mounted on the frame, would you have to think about flexing the body ?
Kevin
Re: pic's of torque straps [Re: superbee500] #898193
01/06/11 11:13 PM
01/06/11 11:13 PM
Temperance, MI
P
P
Temperance, MI
Been 10.40's with what you see with no frame connectors, stock motor mounts and that strap
Re: pic's of torque straps [Re: superbee500] #898194
01/06/11 11:20 PM
01/06/11 11:20 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I dont have a pic of the torque strap I installed in the Duster.. and its too dang cold to go and take one... but what I did was bought a steel turnbuckle from the local hardware store and bolted one side to the head and the other side to thru a mounting hole for the sway bar in the frame..
Real simple, real cheap and it works well..
Re: pic's of torque straps [Re: Jeepmon] #898195
01/06/11 11:24 PM
01/06/11 11:24 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Ive got the same thing as Jeepmon -- here :
Re: pic's of torque straps [Re: prochargedhemi] #898196
01/06/11 11:28 PM
01/06/11 11:28 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Now thats the best looking torque straps that I have ever seen. The way it's double plated on the frame won't flex a bit . Mounted on high on the water pump ,torque twist will be more controlled. You should put them on the market, should be able to sell a bunch.
Re: pic's of torque straps [Re: rowin4] #898197
01/06/11 11:33 PM
01/06/11 11:33 PM
Temperance, MI
P
P
Temperance, MI
Thanks for the kind words. I would try and market them but after doing several other lightweight pieces im burnt out on mass producing this stuff on the side. however i will give anyone that is interested all the dimensional info they need
Re: pic's of torque straps [Re: superbee500] #898198
01/09/11 03:31 AM
01/09/11 03:31 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Here's mine, it's made out of a piece of magnesium with a rubber bush at the chassis rail to cut vibration a little [street car]
Re: pic's of torque straps [Re: Mcode69] #898199
01/09/11 11:19 AM
01/09/11 11:19 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I cut off the lower "eye" from a rear shock and used a short piece of angle and bolt to mount the base to the K frame. This was also welded to a hind joint. The rubber insert in the "eye" stopped any vibration (street car). I then used threaded rod and another hind joint to bolt to the head.
Re: pic's of torque straps [Re: DANA60] #898200
01/09/11 01:45 PM
01/09/11 01:45 PM
Whitinsville Ma
Whitinsville Ma
Thank you for your replies
