Page 2 of 8 1 2 3 4 5 6 7 8
Re: 1000 hp guys or better [Re: earthmover] #897858
01/06/11 08:39 PM
01/06/11 08:39 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
i have heard good and not so good on aluminum rods the good being that they are lighter and lets the motor rev. and little more..the not so good is they dont last as long the life span is not as long and need to be changed more often..now dont take that as word cause i really dont know i have never made any hp like this or used alum. rods before..also this will help answer alot of ?? for my build on the 750hp..now he may use alum. i just cant say and love the ups and downs on the rods..mike
People sometimes treat their stuff poorly and wonder why it fails. I warm my oil to 120* minimum before making a pass and 100* before reving more than 1500. But some don't and the rod doesn't have a chance to grow to it's clearenced size. Steel lasts longer but is harder on everything else. And steel big end gets out of round too. Aluminum should be replaced every 200-250 passes in a natually aspirated engine, but some people, and mopar people say that's not true. I just do it out of habit, but you need to decide for you. I like them better than steel for a race only application. Also, I wonder if that 572-13 motor had 2 carbs?
Re: 1000 hp guys or better [Re: earthmover] #897859
01/06/11 08:39 PM
01/06/11 08:39 PM
SW WI
cudacustoms1 Offline
SW WI
KB stg 6 block.4.31 bore/4.15 stroke. Brooks alum rods. Weisco pistons.8.4 to 1 comp. Callies magnum crank.572-13 heads 370ish @.800.Littlefeild 6-71 std hilex.Bird catcher hat on alky. msd pro mag 20.35 degrees timing. 1124hp 904 tq. 1to 1 drive on the blower.After using the indy heads I would also recomend something else for a new build. They defenetly were limeting use with our deal.
Re: 1000 hp guys or better [Re: camastomcat] #897860
01/06/11 09:11 PM
01/06/11 09:11 PM
virginia
572stealth Offline
572stealth  Offline
virginia
Car is 2300lb w/driver, 727, 9"w/4.10, M/T 3084s (16x33), 572 B1MC heads flow 440, 15.2-1, hogan w/2 prosystem 1100's, cam is 288/306, calles 4.5, Groden 7.1", mega block, Motor is on it's 13th season. Best pass is 4.88 1/8th and 7.65 1/4.
Re: 1000 hp guys or better [Re: earthmover] #897861
01/06/11 09:35 PM
01/06/11 09:35 PM
Delray beach, Florida
P
Performance Only Offline
P
if you dont mind could/would you give a run down on the combo of parts used?? if you dont mind..looking at diff. set up and like to yes whats working for those that are doing it..thanks mike
car
weight
engine spec
trans
gear
tire
this is what my buddy is planned out so far not set in stone ye t...
dodge stratus tube chasiss car..being worked on now
world block
572 with 572heads poprted and polished
762 lift cam with jesal 1.6 rocker
intake ????
piston ?????
rod ?????
crank?????
trans glide
ford 9" rear coil over 4 link
looking for at lease a 1000hp or more for the combo on this build...
i hope you don't take this the wrong way, but real horsepower and internet horsepower are often 2 completely different things.
with that being said, the combo you have outlined IMO is way short of making 1000 real honest horsepower. we've done plenty and have track results to prove it. it's alway's easy for people to tell you what you need when it's not thier engine. all i can tell you is that if we were building it, we'd really have to sit down and have a nice long discussion about you choices so far. i don't mean to be negative or anything like that, but i have to call it as i see it.
machine shop owner and engine builder
Re: 1000 hp guys or better [Re: Performance Only] #897862
01/06/11 09:40 PM
01/06/11 09:40 PM
detroit area
moderncylinder Offline
detroit area
i wouldnt use a 572-23 head,, its not big enough or moves enough air to safley make 1000 hp,,, and run down the track like it has 1000hp... the track is the real tell tale
use a b1 mc,,, pso,, or predator,,, a head that flows 440 or so...at least
Re: 1000 hp guys or better [Re: moderncylinder] #897863
01/06/11 10:10 PM
01/06/11 10:10 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I totally agree with the last 2 comments. Sit down with the engine builder, parts expert or whatever. People on this and other internet sites throw numbers around like gospel and dyno #'s don't mean jack if the car doesn't do what you want it to do. Pick an et goal and talk with one of these guys that does it for a living. Bob George, Koffel, Best Machine, MMotors, and the last two that replied will help you reach that goal. Sorry if I didn't mention someone else, but all of these guys come to mind as people with good reps.
Re: 1000 hp guys or better [Re: camastomcat] #897864
01/06/11 10:13 PM
01/06/11 10:13 PM
Missouri
galen Offline
galen  Offline
Missouri
I was under the understanding he already has the 572-13 heads. Typical of this site anymore. just another whos head is best argument.
Re: 1000 hp guys or better [Re: galen] #897865
01/06/11 11:06 PM
01/06/11 11:06 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
For all out heads(non-Hemi) in order of power and flow:
*Indy Wedge(440-1, 572-13)
*B1(MC, PSO)
*Predator
Re: 1000 hp guys or better [Re: B1Fish540] #897866
01/06/11 11:19 PM
01/06/11 11:19 PM
nc
E
earthmover Offline OP
E
nc
hey guys no problem and i am glad of all the info there is no neg. to what you said dan you are right ..he is just looking and getting a feel of what is out there and whats it doing..internet racing i guess....as far as heads he already have them so i really dont no much but they are the 13's...he has been working alot with the weather we have had here in nc and cant get to make alot of calls but say he has talk to a few that i gave the info on...we all no that every motor is diff. and every motor will not make the same...so thanks for the post and lets keep them coming it is good learing tread...also i would like to say i give a big to you guys that build this kinda motor cause it is alot of stress just for me to ask and reply some of it to him lol..
Re: 1000 hp guys or better [Re: B1Fish540] #897867
01/06/11 11:20 PM
01/06/11 11:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
A guy in my area has a tube chassis GTO with a motor from Kaufmann's that dyno'd 1000HP. It runs 9.50's at the track. Seems like everyone at my track has a 1000HP motor anymore, but they run the same or slower than my 3200# muffled car with 650HP.
Any pics of the engine combo's posted so far?
Re: 1000 hp guys or better [Re: B1Fish540] #897868
01/06/11 11:22 PM
01/06/11 11:22 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
*B1(MC, PSO)
*Predator
The b1-TS head should be in that equation right around the Predator.
Re: 1000 hp guys or better [Re: moderncylinder] #897869
01/06/11 11:57 PM
01/06/11 11:57 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Yes you can make over 1000 (Real, safley) HP with the Indy 572-13 Cylinder Head with there CNC Porting. We have done it many times, with the right combination of parts. We can help you will this, give us a call, and yes we are a sponsor of this site
Re: 1000 hp guys or better [Re: Diablo] #897870
01/07/11 12:17 AM
01/07/11 12:17 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
*B1(MC, PSO)
*Predator
Dont know why i forgot that one, Diablo...Only thing thats different is you need a Hemi block, correct me if I am wrong.
Re: 1000 hp guys or better [Re: B1Fish540] #897871
01/07/11 12:23 AM
01/07/11 12:23 AM
sg66mopar Offline
sg66mopar  Offline
Guys, you're makin' me here. All this time I thought my 572 B1 MC deal was makin' 1100 or more.
Re: 1000 hp guys or better [Re: joshking440] #897872
01/07/11 12:25 AM
01/07/11 12:25 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
unported B1 heads
small roller cam
single dominator
1400hp
1000 ftlbs of torque
oh, yea a 106mm turbo
This makes sense.
Too late for me now , but my next deal will have some type of forced induction on it.
This seems to be the easiest and most reliable way to make monster numbers and not kill parts.
I haven't done any numbers seriously , and it has the slightly more expensive feel to it , but I also think it will pay off long term with less maintenance and parts required to keep it strong.
Re: 1000 hp guys or better [Re: earthmover] #897873
01/07/11 01:13 AM
01/07/11 01:13 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
car1968 Plymouth Barracuda, mild steel, square tube chassis 7.50 cert
weight2875 race ready full of fuel
engine spec525" B1/MC(oval ported by Mike Duke), 15.5-1, Callies Crank, GRP rods, CP pistons, 282/296 55MM Bullet Cam, T&D rockers, Unported single 4 intake, Gary Williams Dominator
trans1.80 Powerglide with tight ATI 8" stop converter
gear4.30
tire15x33 M/T Stiff sidewall
Fills in the blanks I suppose. This is the newest incarnation of this motor since we freshened it up. Also has a bit more weight in it to help bias a bit. Anyway my internet race car has been 8.0's at 168 and change going through the traps at 7450, in very good air. Admittedly I run the car on the stop most of the time. I typically will go 154-6 at 10.90, been 159 and change on the stop. Car makes peak HP at 7700 peak torque at 6400. Of course maybe the dyno was happy that day but it was well over 1000hp. You all can plug in the numbers to whatever you like and do the math.
We have never really chased ET with the car. I am a stop racer. I am more concerned with how it runs onthe stop than all out. I am completely confident that it can go a bit quicker than we have been. I am under geared and the converter is WAY tight. Shift recovery is ridiculously slow. At any rate that is how I got there.
Re: 1000 hp guys or better [Re: Al_Alguire] #897874
01/07/11 08:48 AM
01/07/11 08:48 AM
pa
572charger Offline
572charger  Offline
pa
at that price level id just build a hemi !!! my street ported [ray barton] stage v 's flow 455 at 700 lift ! ive got steel oliver rods , callies crank 4.750, in a non raised cam mopar block , diamond pistons 11.7 to 1 comp [pumpgas] 700 lift roller prosystems carb on a ray barton intake never had it dynoed but it made my 3910lb steet car go 9.60 at 141mph in a3000 lb car i bet it would go 8s on sheets gas !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 1000 hp guys or better [Re: tubtar] #897875
01/07/11 10:58 AM
01/07/11 10:58 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
unported B1 heads
small roller cam
single dominator
1400hp
This makes sense.
This is the only way I would look to make big HP using what he has already!
Re: 1000 hp guys or better [Re: B1Fish540] #897876
01/07/11 12:36 PM
01/07/11 12:36 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
*B1(MC, PSO)
*Predator
I know the two TS engines I have are both based on the Hemi Bolt pattern but I have read of some being used on modified RB blocks. But you are right the Hemi pattern is standard.
Re: 1000 hp guys or better [Re: Diablo] #897877
01/07/11 03:26 PM
01/07/11 03:26 PM
detroit area
detroit area
with 572-13 head you make a solid 950hp,, which would still be fast in a 2350lb car...
i know guys around here that made 1000 or a lil more then put it in their 3300lb car and run 8.80's,,, look at westcott's stick car making a lil under 1000 running 8.20's in a 3200lb car,,, those guys with over 1000 prob really had a lil over 900
