Re: Antenna Question
[Re: 451Mopar]
#895876
01/04/11 10:58 PM
01/04/11 10:58 PM
Posts: 1,822 Colorado
denfireguy
Colorado
My '69 Convertible has a fixed length antenna, and the base has a nut that takes a larger antenna nut wrench than the replacement '69 telescoping antenna. Is the one on the car original or aftermarket? The fender tag decodes for the AM/FM radio if that matters?
Telescoping is what the car came with. The later antenna that Barry shows was also installed at the dealership after 1971 if it was repaired. My mom's 70 station wagon had the old style antenna snapped off by vandals and the insurance company put the later style antenna on at the dealership. The radio will work but you will have to adjust the trimmer capacitor for the new length. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
