electric choke wire...where????? EDELBROCK
#89526
07/16/08 06:11 PM
07/16/08 06:11 PM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
1406 edelbrock carb, my choke wire fell off, the red one, does it go on the pos. side of the coil?? My engine has been cutting out, may be choke related, the wire fell off.........any help is good........also the coil i had was not labeled pos or neg i tested it when i hooked it up....where does the brown wire go? its in a 73 challenger....Mike
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
Re: electric choke wire...where????? EDELBROCK
[Re: sthemi]
#89528
07/16/08 07:24 PM
07/16/08 07:24 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A '73 has two field wires, be sure to use the blue one not the green one; the double blue wire on the ballast is the same circuit.
[Re: John_Kunkel]
#89530
07/16/08 08:54 PM
07/16/08 08:54 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Use the blue wire coming off the ballast resistor. It should have hot power when the ignition switch is in the start and run position.
[Re: In_The_Pink]
#89531
07/16/08 09:02 PM
07/16/08 09:02 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
He should not have to do anything the factory choke wire should be there.
[Re: NITROUSN]
#89532
07/16/08 09:07 PM
07/16/08 09:07 PM
In_The_Pink
Milwaukee, WI
True, provided it has not been cut off or removed.
The brown wire is the positive (+) power for the coil.
[Re: In_The_Pink]
#89533
07/17/08 01:06 AM
07/17/08 01:06 AM
PlumCrazy73Dodge
New Jersey, US of A
thanks guys i think the problem may be a broken valve spring after all...the choke wiring issues...the blue wire has been cut/played with by someone the little plastic bo where the wires stem from is a mess...needless to say i think its time to pull the motor and give it a new paint job anyway...
