1406 edelbrock carb, my choke wire fell off, the red one, does it go on the pos. side of the coil?? My engine has been cutting out, may be choke related, the wire fell off.........any help is good........also the coil i had was not labeled pos or neg i tested it when i hooked it up....where does the brown wire go? its in a 73 challenger....Mike
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
