Re: Comp 829 roller lifter-Oil soak before spring?
[Re: Cab_Burge]
#894882
01/02/11 08:46 PM
01/02/11 08:46 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Did you do any "winterizing before parking it? Either way pulling the distributor and priming the oil system and then turning the motor over, with the spark plugs removed, on the starter while priming it can't hurt
Only winterizing I did was to pull the plugs and spray some storage oil down the cylinders. 50/50 mix of anti freeze in a dry and relatively warm (doesn't get bellow 32 degrees).
Don't want to pull the intake unless it's necessary.
[Re: torkrules]
#894883
01/02/11 10:21 PM
01/02/11 10:21 PM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
Aren't you firing it up once in a while John? Give me a call this week, I'm back staring tomorrow. Steve
Photobucket sucks
[Re: 72chrgrally]
#894884
01/02/11 10:25 PM
01/02/11 10:25 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Dont worry about them. They would need less oil than a standard lifter, seeing how they a re needle bearing style. Is the lifters bushed? Just prime the engine in the spring
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
