W9 Headers Pics.., Advice? #893462
01/01/11 11:08 AM
01/01/11 11:08 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I will be contemplating this in the future on a stock Abody chassis.I will get them done by a header builder of course. just trying to get info here before I do and see some pics and suggestions. Thanks.
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893463
01/01/11 11:13 AM
01/01/11 11:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Here's my W-9 header... these are a 3 step
Re: W9 Headers Pics.., Advice? [Re: MR_P_BODY] #893464
01/01/11 11:19 AM
01/01/11 11:19 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Did you have to trim those flanges, or just preference? Nice job. Thermostat housing looks great too.
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893465
01/01/11 11:25 AM
01/01/11 11:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Trim the flanges? thats the way I made them... not
sure what you get when you buy them... I also have
a couple sets of SS flanges purchased from a member
here but they are all one piece... myself I would
cut them into 3 pieces for expansion (like mine)
Re: W9 Headers Pics.., Advice? [Re: MR_P_BODY] #893466
01/01/11 11:28 AM
01/01/11 11:28 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Oh I see. I'll bet they seal better that way too. What are the ports on the top by the head?
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893467
01/01/11 11:33 AM
01/01/11 11:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You mean the casting bumps between the headers...
those are for injection
EDIT
If you are talking the bungs on the headers, those
are for EGTs... I put them on all the headers I made
unless not wanted
Re: W9 Headers Pics.., Advice? [Re: MR_P_BODY] #893468
01/01/11 11:34 AM
01/01/11 11:34 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
No I mean on top of the tubes, maybe some kind of egt sensor?
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893469
01/01/11 11:38 AM
01/01/11 11:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I edited my post... they are EGTs
Re: W9 Headers Pics.., Advice? [Re: MR_P_BODY] #893470
01/01/11 11:39 AM
01/01/11 11:39 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
[quoteEDIT
unless not wanted
Thanks!
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893471
01/01/11 01:08 PM
01/01/11 01:08 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Just my
You can get a set of TTI's for W2 or W5 in raw form (uncoated) And cut the flange off, and weld a W9 flange on. To save some money.
Once the Flange is cut off the tubes move around enough to mate up with W9 ports.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: W9 Headers Pics.., Advice? [Re: DemonDust] #893472
01/01/11 02:27 PM
01/01/11 02:27 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Just my
Jesse,
Is this something you have done, seen done or just figure would work?
Thanks,
Bill
Re: W9 Headers Pics.., Advice? [Re: 340Cuda] #893473
01/01/11 03:17 PM
01/01/11 03:17 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I did it years ago on Aluminum block W9 setup I was going to use in my duster. But I changed directions. It worked great and was very simple if you have fab/welding skills...
SDG Motorsports
Re: W9 Headers Pics.., Advice? [Re: DemonDust] #893474
01/01/11 04:10 PM
01/01/11 04:10 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Jesse, did you use a motor plate? I have tti w2's, but the exhaust port is very high on a 9, also the heads look wider.
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893475
01/01/11 05:22 PM
01/01/11 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For a mock up I would set the engine in place and see
if your W-2 headers line up... I have cut flanges off
and welded on different ones... just make sure they
clear
Re: W9 Headers Pics.., Advice? [Re: MR_P_BODY] #893476
01/01/11 06:35 PM
01/01/11 06:35 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
clear
Sounds like its worth checking out. I plan on going with 440+ cubes, dont know at what line a bigger tube would be beneficial. Thanks for the info guys.
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893477
01/01/11 07:44 PM
01/01/11 07:44 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The w9 exhaust port is DEFINATELY higher then a w2/w5. You'd have to be careful about clearance to the rest of the suspension if you were going to do that.
It's the same reason a -1 Indy Big Block header is different from a conventional head, and drove Indy to create EZ line of heads.
I've yet to see a set of w2/w5 headers, actually put into a car with w8/w9 heads. You'd think if it was that easy, TTI would just weld on different flanges, and market them to us...
Not saying it can't be done, I'm just saying be careful before you blow a bunch of money on a set of headers that won't actually fit in the car...
Re: W9 Headers Pics.., Advice? [Re: dizuster] #893478
01/01/11 08:01 PM
01/01/11 08:01 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
biggest problem with putting W2 headers on W8/9 is plug clearance especially on 5/7. The plug location & angle on an 8/9 is so far from any normal 18 degree head that plug wire access is tough. I had Heddman W2 headers on my old W8 motor with modified flanges & had to install plug wires on 5/7 from under the car with a pair of needle nose pliers.
& then the biggest problem with trying to do a set of TTI's is they are very restrictive for a 680+ HP motor, so what's point of building a killer W9 motor & bottle neck it with a restrictive TTI header?
If you're gonna try to use an off shelf header & mod it, I'd do a 2" tube Heddman W2 & start with that.
Re: W9 Headers Pics.., Advice? [Re: MR_P_BODY] #893479
01/01/11 08:11 PM
01/01/11 08:11 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
1 simple word (CUSTOM)
Re: W9 Headers Pics.., Advice? [Re: RyanJ] #893480
01/01/11 08:13 PM
01/01/11 08:13 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I forgot you telling me about the plug problems it would have. Who builds a nice header within reasonable driving distance of western Pa?
Re: W9 Headers Pics.., Advice? [Re: Hot 340] #893481
01/01/11 08:35 PM
01/01/11 08:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want PM me and I'll run your engine through
my header program... I'll need info
