Re: 68 Barracuda Rocker Panel (spear) molding clip ????
[Re: Russ H.]
#891227
12/30/10 01:09 PM
12/30/10 01:09 PM
Russ H.
[Re: 68mannix]
#891229
12/30/10 03:04 PM
12/30/10 03:04 PM
Russ H.
if its like the 69 dart gts spear they sell plastic repos that i couldnt get to work, so i went to local auto paint supply and bought some metal spring clips that work great.
Is the 69 Dart trim a thin spear, about 3/4 of an inch tall? I too, bought the plastic repro clips and do not think they will work. Also, can you post a picture of the metal spring clip??
Thank you,
Russ
[Re: 68mannix]
#891231
12/31/10 05:02 AM
12/31/10 05:02 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
I just went in the garage and measured for you. I have the original spears on my 68 Cuda and have a set of primo used spears I got at last Fall Fling that I have started sanding and polishing allready.
The O.D. measure:
Dart Rocker Spear: 0.74"
68 Barracuda Rocker Spear: 0.82"
[Re: Russ H.]
#891233
12/31/10 02:02 PM
12/31/10 02:02 PM
autoxcuda
So Cal
Autoxcuda,
Thank you for the measurement. It would be much appreciated if you would measure the inside channel where the clips sit. (I don't presently have access to mine, they were sent out for re-finishing.
Thank you,
Russ
My cuda spears on installed on the car. Do you want the Dart measurement?
[Re: autoxcuda]
#891234
12/31/10 03:49 PM
12/31/10 03:49 PM
Russ H.
Autoxcuda,
Thank you,
Russ
No, but thank you for the offer, I appreciate your help.
Russ
