Re: 727 transmission full manual valve body ?
[Re: 410mopar]
#890608
12/28/10 09:08 PM
12/28/10 09:08 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
you will need to purchase a VB
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Voluster]
#890619
12/29/10 11:10 AM
12/29/10 11:10 AM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif) CRT,John fixed me up a full manual foward shift low band apply VB used the CRT billet low/revs servo also no kickdown linkage for my 88 440 truck IIRC the trans go-3 shift kit makes it full manual shift,but forward shift pattern thats a nice street rod too ![](/ubbthreads/images/graemlins/bow.gif)
[Re: 410mopar]
#890620
12/29/10 12:17 PM
12/29/10 12:17 PM
Posts: 16,932 NC
440Jim
NC
Plus I want the braking effect in first gear. I also like the reverse shift pattern. 1) So, is a Griner VB an easy swap? I was told I would also need to change the reverse servo arm to a 4.2 if I went with a manual VB. Could I still run the stock arm? Don
My Griner manual valve body has low band apply (1st gear braking). The lever arm is for the front band, not the rear.
Front sevro/band and lever: 2nd gear Rear servo/band: 1st (if low band apply) and reverse (all valve bodies)
I use a 3.8 lever, so I see no problem with a 3.2 or 3.8, or even the 4.2. The billet rear servo is a good idea if you are going to be down shifting to 1st (rear servo/low band apply). I like the $75 kit that Randy sells with a heavy duty spring and retainer with the servo, see the parts for sale section of this web site.
[Re: Exit1965]
#2685433
08/07/19 05:49 PM
08/07/19 05:49 PM
Posts: 28,621 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I am running the T/A reverse manual There are some now that let you do 1st gear burnout though. I know CRT used to recommend one that did as he use them in his builds .
[Re: slantzilla]
#2685694
08/08/19 01:14 PM
08/08/19 01:14 PM
Posts: 422 montana
BANDIT
montana
Contact member 727specialists. He assembles valve bodies for Griner. Keith will take care of you. <img src="/ubbthreads/images/graemlins/beer.gif" alt="" /> I would go with this fellow before Cope. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: 410mopar]
#2685700
08/08/19 01:26 PM
08/08/19 01:26 PM
Posts: 4,213 New York
polyspheric
New York
W/r/t "Due a design error there is no way to connect the kick down/throttle linkage. I was told the only way to do away with that linkage is to go to a full manual valve boddy" Let me translate: the person who told you this doesn't know how.
Drove a full manual on the street 50 years ago. Gets old 10 minutes into traffic. I actually wore out the detent steps in the shift gate. Can't drive the car at all if it rains in the next town, the car will loop at 10 mph on the 1-2 shift unless the wheels are straight. A loose converter fixes a lot of this, but is that what you want?
Boffin Emeritus
