Re: 727 Transmission help- No reverse
[Re: 410mopar]
#890531
12/28/10 08:43 PM
12/28/10 08:43 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
TP linkage won't affect Reverse. You can't modify a stock VB to manual reverse with LBA from a kit.
Since the servos air check OK the problem has to be in the VB, possibly in the manual valve or a missing check ball. If the large check ball is omitted when reassembling the VB there will be no Reverse.
