Take A Guess #888725
12/26/10 05:33 PM
12/26/10 05:33 PM
MR_P_BODY Offline OP
This is just for fun and something I most likely wont
know unless you base it on the on track performance
Guess the HP and torque
What I have is a
340 stock block with 4 bolt caps at 4.070 bore
4" stroke crank turned down to chevy rod size (2.1")
6.125 Eagle H-beam rods
Diamond pistons with a 18cc dish and valve pockets
which will be either a 10.75 OR 11.02 compression
depending on which head gaskets
cam is a roundy round solid roller 260/270@50 .610/.610
lift on a 105 LSA installed at 105
TD rockers with push rod oiling 1.5/1.5... but I'm
checking my stash to see if I have any 1.6 intakes
W-5 ported heads.... 2.08 intakes, 1.6 exhaust both
are .343 stems peak flow is 310 cfm
M1 intake with 4500 adapter and a 1050 dom, match
ported to the heads
custom wet sump oil pan with scraper
1 7/8" headers
This is a pump gas engine
I think thats about it.... take a guess.... this is
going into my Rampage... this will be my Hot Rod
Drag week car and my street hot rod ... I expect it
to be at or a little less than 2800# with me
Re: Take A Guess [Re: MR_P_BODY] #888726
12/26/10 05:36 PM
12/26/10 05:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not good at this but here goes;
575-590 hp
525-550 tq..........but have no clue at what rpm`s.
Re: Take A Guess [Re: MR_P_BODY] #888727
12/26/10 05:44 PM
12/26/10 05:44 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
..... 565 hp @ 6750 and 530 ft lbs @ 5300,am I close?
Re: Take A Guess [Re: MR_P_BODY] #888728
12/26/10 06:03 PM
12/26/10 06:03 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Im going to say around 525hp on the plus side ...make at least 450 lbs ft..
Re: Take A Guess [Re: smokinwoody] #888729
12/26/10 06:11 PM
12/26/10 06:11 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
with Woody, low to mid 500's.
Re: Take A Guess [Re: MR_P_BODY] #888730
12/26/10 06:22 PM
12/26/10 06:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
4.070 bore on a stock block
Re: Take A Guess [Re: rebel] #888731
12/26/10 06:23 PM
12/26/10 06:23 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
535HP 480tq
Mopar Performance
Re: Take A Guess [Re: moparniac] #888732
12/26/10 06:26 PM
12/26/10 06:26 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
545
Re: Take A Guess [Re: Quicktree] #888733
12/26/10 06:26 PM
12/26/10 06:26 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Its a 340 block Quick
Re: Take A Guess [Re: moparniac] #888734
12/26/10 06:26 PM
12/26/10 06:26 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
conservative 575hp,i'f all else is good..10.30's in a 2800 lb car
Re: Take A Guess [Re: emarine01] #888735
12/26/10 06:27 PM
12/26/10 06:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
so it's .030 over. i was thinking something else
Re: Take A Guess [Re: MR_P_BODY] #888736
12/26/10 06:32 PM
12/26/10 06:32 PM
NC
440Jim Offline
440Jim  Offline
NC
I know it isn't a full up race engine, but I know a guy that ran a 422 CID, small block with W5 heads, and it was way faster with his W2 heads. But that isn't fair as the W2 heads were heavily ported, and much smaller chambers (CR). As I recall, in a roughly 2700 pound car, around 10.0
Re: Take A Guess [Re: 440Jim] #888737
12/26/10 07:04 PM
12/26/10 07:04 PM
As a guess myself I'm thinking 550hp with 500tq I might
be a bit high but I'm hoping for 500ft lbs on torque
I'll be running a 518 OD trans with a 4500 stall
or there about converter( I think it would be closer
to 6000 but I'll send it out to have it corrected
to my engine).... I can only run 10.0 at ANY track
and 10.80 at the Hot Rod week stuff
Re: Take A Guess [Re: MR_P_BODY] #888738
12/26/10 07:15 PM
12/26/10 07:15 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
You know where its gonna fall in and what you need to tweak to get it there Sounds like a fun build
Re: Take A Guess [Re: MR_P_BODY] #888739
12/26/10 07:32 PM
12/26/10 07:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why are you limited to 10.0? saftey rules? what about the the 423ci NA class?
Re: Take A Guess [Re: MR_P_BODY] #888740
12/26/10 07:41 PM
12/26/10 07:41 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I think about 615hp
Re: Take A Guess [Re: Quicktree] #888741
12/26/10 07:45 PM
12/26/10 07:45 PM
I can NOT get a NHRA license anymore due to health reasons
so I am limited to 10.0 MAX... and in this participial
field they have a 10.80 cut off with a average of
10.80... BUT they deduct .1 from your weekly average
Re: Take A Guess [Re: MR_P_BODY] #888742
12/26/10 07:51 PM
12/26/10 07:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
oh yea I forgot. what was the winner in last years SB NA class? sounds like fun I am thinking about doing something like this.
Re: Take A Guess [Re: Quicktree] #888743
12/26/10 08:05 PM
12/26/10 08:05 PM
Its bracket racing on the final day so its up to the
best off the line on the last day... I just want to be
competitive.... but I would like to have a little in
the bank
Re: Take A Guess [Re: MR_P_BODY] #888744
12/26/10 08:10 PM
12/26/10 08:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mike, with the roundy bout roller cam you may want to look @ a 1.7 intake rocker
