Re: {{{{ THREADED TUBING }}}}
[Re: DusterDave]
#885704
12/22/10 09:20 PM
12/22/10 09:20 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Where are you guys getting it....????? Need (2) 12" lengths of 5/16 OD that I can tap to 1/4-24 I believe is fine thread right...???? It's for a progressive linkage setup the has (2) short lengths that ain't gonna work
Could get away with (1) 12" piece, but will make one non-progressive just in case I want to change it later
Rickster
1/4-28 is fine thread. You can use 5/16" OD tubing that has a 3/16" or smaller ID, drill out with a #3 or 7/32 bit, and tap your 1/4-28 thread.
Where can you get it locally Dave....?????? 1/4-28 that's it...have the drills & taps was just too lazy to go look....lol
Yes aluminum
Rickster
[Re: MR_P_BODY]
#885705
12/22/10 09:45 PM
12/22/10 09:45 PM
rickstershemi
Sorry cant help... I drill and tap that stuff in my lathe... 1/4 X20 or 1/4 X 28... I assume you want alum
Sure you can....I'll take (1) 12" length (1) 7" & (1) 5" Please....you don't even have to polish it
Rickster
[Re: rickstershemi]
#885706
12/22/10 09:55 PM
12/22/10 09:55 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
ART in Pinelis has all the dom you want call them and you can get it next day
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: rickstershemi]
#885707
12/22/10 09:55 PM
12/22/10 09:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Rickster
I can if you want me too... wish I would have known earlier today... I was at the steel place picking up a few pieces
[Re: MR_P_BODY]
#885708
12/22/10 11:22 PM
12/22/10 11:22 PM
rickstershemi
Rickster
I was just kidding Mike, but might take you up on it if I can't find any tubing locally, but should be able too
But Thanks....!!!!!
Rickster
[Re: rickstershemi]
#885711
12/22/10 11:33 PM
12/22/10 11:33 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
You can get tube adapters from ANY chassis shop. They are welded in, come in left and right hand thread. We usually get ours from here http://secure.chassisshop.com/But A.R.T is closer to you.
[Re: rickstershemi]
#885713
12/22/10 11:48 PM
12/22/10 11:48 PM
MR_P_BODY
This is for the tunnel ram linkage right... if so I use to run 1/4" solid alum drilled and tapped for 10/32.... that still leaves .032 wall on each side... if its adjusted right you are only overcoming the return spring so its plenty strong enough
[Re: MR_P_BODY]
#885714
12/23/10 12:06 AM
12/23/10 12:06 AM
rickstershemi
I have a progressive setup and all the pieces are 5/16 fairly thick wall, but too short....need to either find the right tubing or just go with a non-progressive setup....have plenty of time
Rickster
[Re: SB412DUSTER]
#885717
12/23/10 09:17 AM
12/23/10 09:17 AM
rickstershemi
Rick Home Depot or Lowes has 5/16 round aluminum rod, wouldn't that work? just drill and tap
Thanks Laverne, I'm planning on ck'ng both today...drilling & tapping is not an issue
Rickster
