Where are you guys getting it....????? Need (2) 12" lengths of 5/16 OD that I can tap to 1/4-24 I believe is fine thread right...???? It's for a progressive linkage setup the has (2) short lengths that ain't gonna work
Could get away with (1) 12" piece, but will make one non-progressive just in case I want to change it later
Rickster
1/4-28 is fine thread. You can use 5/16" OD tubing that has a 3/16" or smaller ID, drill out with a #3 or 7/32 bit, and tap your 1/4-28 thread.
Gone to the dark side with an LS3 powered '57 Chevy 210
