Re: Best front disc. set up for street/strip car... [Re: AndyF] #884411
12/21/10 08:28 AM
12/21/10 08:28 AM
pa
572charger Offline
572charger  Offline
pa
been using wilwoods front [vented rotors] street duty stuff on my 3910 lb car since 2003 with absolutely no problems what so ever !!! i've installed them on many cars also without a hitch in 2007 i installed the pro street w/ park brake on the rear with a wilwood master cylinder! we have a short shut down at our home track and i have no problems stopping at 154mph then drive it home stopping at stop signs and red lights, 2nd best investment on my car!!!! [1st was the hemi ]
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Best front disc. set up for street/strip car... [Re: topbrent] #884412
12/21/10 12:49 PM
12/21/10 12:49 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
I have used Andy's kit a couple of times. No issues at all. In fact the one on the belvedere has ben there for 10 years and thousands of street miles and a few hundred passes with ZERO issues. Great product and a good compromise for a street strip car.
Re: Best front disc. set up for street/strip car... [Re: Al_Alguire] #884413
12/21/10 11:33 PM
12/21/10 11:33 PM
AndyF Offline
AndyF  Offline
Al, you must be one of the original buyers of that kit. I started to make the Wilwood adapter back in 1999 so it has been just a little over 10 years.
I recently designed a kit that uses radial mount Wilwood calipers. These calipers have weather seals on the pistons and the radial mounting is more rigid than the ear mounts. But the radial mount calipers are a lot more expensive than the older ear mounts so this new kit hasn't been very popular. It is what I'd use on my car if I was going this way, but the price point seems to keep people from buying it.
Re: Best front disc. set up for street/strip car... [Re: AndyF] #884414
12/21/10 11:38 PM
12/21/10 11:38 PM
Get-X Offline
Get-X  Offline
I recently designed a kit that uses the radial mount Wilwood calipers. These calipers have weather seals on the pistons. The radial mounting is also more rigid than the ear mounts. But the radial mount calipers are a lot more expensive than the older ear mounts so this new kit hasn't been that popular.
Where does one get the rotors for this? I have a WW kit with a solid rotor that I may steal the Dynalite calipers from and put them on the GTX. It has factory KH discs but I wouldn't mind saving a few pounds.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Best front disc. set up for street/strip car... [Re: Get-X] #884415
12/22/10 12:58 PM
12/22/10 12:58 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
this might be stupid question, can a 70 e-body stock style disc master and brake booster be used with the wilwood calipers? i have a set of brand new 11.75 rotors already, i would only need to get the correct spindles and caliper brackets,right?
Re: Best front disc. set up for street/strip car... [Re: SV_MOPARS] #884416
12/22/10 03:53 PM
12/22/10 03:53 PM
IN
ahy Offline
ahy  Offline
IN
The master should work fine... with an adjustable prop valve for the rears to set F/R balance. Add bearings, seals and dust caps to your shopping list and I think you have it.
Re: Best front disc. set up for street/strip car... [Re: AndyF] #884417
12/22/10 11:07 PM
12/22/10 11:07 PM
Utah
topbrent Offline
topbrent  Offline
Utah
AndyF:
http://www.arengineering.com/caliper/wilwood2/wilwood2.html
Andy, I am curious as to why you recommend the radial mount kit for this street/strip application when you note on your website that the radial mount kit is not recommended for street use?
Re: Best front disc. set up for street/strip car... [Re: topbrent] #884418
12/22/10 11:35 PM
12/22/10 11:35 PM
AndyF Offline
AndyF  Offline
That is a different kit. The new radial mount calipers have weather seals.
Re: Best front disc. set up for street/strip car... [Re: Get-X] #884419
12/23/10 02:13 PM
12/23/10 02:13 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
The factory 11.75 inch rotors were used on 76-78 B-body and 79-up R bodies. Raybestos part # 7038R, NAPA part#NB 4885579. I believe Wagner and Bendix also have them but not sure on those part numbers.
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: Best front disc. set up for street/strip car... [Re: Ray440] #884420
12/24/10 05:15 PM
12/24/10 05:15 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
good thread!
Mopar Performance
Re: Best front disc. set up for street/strip car... [Re: Ray440] #884421
12/24/10 05:53 PM
12/24/10 05:53 PM
Get-X Offline
Get-X  Offline
Thank you for the info, much appreciated
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Best front disc. set up for street/strip car... [Re: Get-X] #884422
12/24/10 06:01 PM
12/24/10 06:01 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Anyone using the Baer Claw system year one sells?
Re: Best front disc. set up for street/strip car... [Re: 440forPOWER] #884423
12/24/10 10:19 PM
12/24/10 10:19 PM
AndyF Offline
AndyF  Offline
I've used Baer systems on track cars. They make the best setups for that type of applications. Their street setups are pretty good also, but the rotor size is fairly small.
All depends what you're trying to do with the car.
