Page 1 of 3 1 2 3
Guys with no inner fenders on stock type a-bodies? #883082
12/18/10 03:42 PM
12/18/10 03:42 PM
Idabel,Oklahoma
Gary Robbins Offline OP
Idabel,Oklahoma
Can any of you with the upper control arm in the stock location and no inner fender show me some pic. from under hood,thanks...Gary
Re: Guys with no inner fenders on stock type a-bodies? [Re: Gary Robbins] #883083
12/18/10 04:18 PM
12/18/10 04:18 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I can when I get home but it's not an A body.
What is it your wanting to know or see?
Re: Guys with no inner fenders on stock type a-bodies? [Re: Gary Robbins] #883084
12/18/10 04:19 PM
12/18/10 04:19 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
here you go:
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Guys with no inner fenders on stock type a-bodies? [Re: bigtimeauto] #883085
12/18/10 04:21 PM
12/18/10 04:21 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Heres one when my Valiant was in the body shop.
Re: Guys with no inner fenders on stock type a-bodies? [Re: WILD BILL] #883086
12/18/10 04:24 PM
12/18/10 04:24 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Guys with no inner fenders on stock type a-bodies? [Re: Gary Robbins] #883087
12/18/10 04:37 PM
12/18/10 04:37 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Re: Guys with no inner fenders on stock type a-bodies? [Re: jughed] #883088
12/18/10 04:56 PM
12/18/10 04:56 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i decided the shock mount was interfearring with making some decent flowing headers so we moved the shock mount to the bar & cut the rest out.
Re: Guys with no inner fenders on stock type a-bodies? [Re: rebel] #883089
12/18/10 05:24 PM
12/18/10 05:24 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
Re: Guys with no inner fenders on stock type a-bodies? [Re: Gary Robbins] #883090
12/18/10 06:56 PM
12/18/10 06:56 PM
Butler Pa. USA
rickma Offline
rickma  Offline
Butler Pa. USA
69 dart
Re: Guys with no inner fenders on stock type a-bodies? [Re: rickma] #883091
12/18/10 07:03 PM
12/18/10 07:03 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
whats the pros and cons of this i have thought of doing my duster this way with the new big block but thought i would ask before i do it...i know it helps cool down air flow in compartment and stuff like that maybe clearence for headers aswell thanks sorry dont mean to hi jack just would like to know..mike
Re: Guys with no inner fenders on stock type a-bodies? [Re: earthmover] #883092
12/18/10 07:07 PM
12/18/10 07:07 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the pro's as i see it, you have room to build better flowing headers, you can access your plugs easier especially if you build good headers, on my car the front clip comes off so the front tires become a convieniant seat when working on the engine. i can't think of any cons apart front your engine will get dirty if you drive on the street in the rain.
Re: Guys with no inner fenders on stock type a-bodies? [Re: earthmover] #883093
12/18/10 07:09 PM
12/18/10 07:09 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Here's what mine looks like. A little tough to see the shock mount, but it is tied in with the front runner of the cage.
Re: Guys with no inner fenders on stock type a-bodies? [Re: earthmover] #883094
12/18/10 07:16 PM
12/18/10 07:16 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If it's a race car , ease of header install, plug change, maybe cooling, make sure you have the front cage tubes even if there welded to the firewall or your car will fold up. welding the remaining shock tower to the front tubes will add support also. If your looking for weight reduction , maybe 20 lbs., The down tubes will weigh more. It better be a race car or the value of your car will be reduced.
Re: Guys with no inner fenders on stock type a-bodies? [Re: earthmover] #883095
12/18/10 07:22 PM
12/18/10 07:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you put the round tube in place as the others
show you can cut that sheet metal out and save weight
along with easier access... the upper A-arm carries
very little load... its there to hold the spindle
vertical, thats all(well in the case of a stock
set up its there to adjust the camber and caster)
Re: Guys with no inner fenders on stock type a-bodies? [Re: rebel] #883096
12/18/10 08:59 PM
12/18/10 08:59 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
the pro's as i see it, you have room to build better flowing headers...
What's the spring for??
Re: Guys with no inner fenders on stock type a-bodies? [Re: PolyDart] #883097
12/18/10 09:02 PM
12/18/10 09:02 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it's not a spring but in fact a piece of plastic electrical conduit to hide the hori old chain i use to act as a limiter on the suspension.
Re: Guys with no inner fenders on stock type a-bodies? [Re: Gary Robbins] #883098
12/18/10 09:09 PM
12/18/10 09:09 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Just an fyi - those inner fenders do a lot to strengthen the uni-body. And they will weigh much less than the cage bars you would need to install to regain that strength...you also lose a good many of the places that bolts go into the fenders to hold them in place.
Re: Guys with no inner fenders on stock type a-bodies? [Re: Sixpak] #883099
12/18/10 09:58 PM
12/18/10 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the weight... I disagree with you... thats alot
of metal your taking out... but I use moly tubing
which is 1.36# per foot but if you use MS its 2.0#
Re: Guys with no inner fenders on stock type a-bodies? [Re: Gary Robbins] #883100
12/19/10 12:00 AM
12/19/10 12:00 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Here's my pig.
This was done for cooling, the A-body engine compartment is a hot-house otherwise. Bent bars are weaker in tension and compression. Mine isn't tied to the cage since I don't have one. Fwiw, the horizontal force in the upper control arms is F=W*A/B where W is the sprung corner weight, A is the distance from the center of the tire to the center of the lower ball joint and
B is the distance between the ball joints. Since A and B are similar the horizontal force is similar to the sprung corner weight.
Check out the high-tech cooling system. It's worked fine for at least 15 years and uses no wp housing. The bar code on the valve cover is for a Cordoba HP 400, I just couldn't paint over it. Harland Sharps hiding under the stock covers. I know, I have some clean-up to do, the engine is coming out soon.
Re: Guys with no inner fenders on stock type a-bodies? [Re: @#$%&*!] #883101
12/19/10 12:36 AM
12/19/10 12:36 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you need to build the front so everything ties together using the engine plate and transmission midplates as crossmembers:
Page 1 of 3 1 2 3
