Page 2 of 3 1 2 3
Re: Felpro valley pan fiasco [Re: stumpy] #880373
12/15/10 05:33 PM
12/15/10 05:33 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I remember a thread where guys were discussing epoxy, aluminum foil, steel wool, who knows what else, on blocking the crossover.
I wish I could remember who said it, but it was along the lines of
'if you're gonna pack a bunch of stuff down in the crossover port, make sure to put $100 bills in there too, then when it breaks loose and gets down in a cylinder at least you'll have the $$ on-hand to fix it'...
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880374
12/15/10 05:52 PM
12/15/10 05:52 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
If I try to order one locally I'll probably find the same problem! Any ideas?
Yeah, buy the brand new one I have in my living room. I sent you a pm.
Scott
1969 Super Bee, 383/4 speed
Re: Felpro valley pan fiasco [Re: Fury Fan] #880375
12/15/10 05:55 PM
12/15/10 05:55 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I used orange RTV. Never had a problem.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Felpro valley pan fiasco [Re: Paul_Fancsali] #880376
12/15/10 05:57 PM
12/15/10 05:57 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
If you run the car at all in cool weather or on the street I would leave it open. Cars run better warmer then too cold
True, but only if you have a functioning heat riser on one side to force the exhaust to pass thru. Otherwise it doesn't do its job correctly.
If you don't have the riser, then I'd guess that it won't warm up much faster than with it blocked.
Re: Felpro valley pan fiasco [Re: CJK440] #880377
12/15/10 06:01 PM
12/15/10 06:01 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I'll disagree there, I can't think of the last car of mine that actually had a functioning heat riser.
Yes, a heat riser forces the PS exhaust thru the intake, making warm-up more effective, but if the passage is open it'll still get plenty hot.
Re: Felpro valley pan fiasco [Re: Fury Fan] #880378
12/15/10 06:08 PM
12/15/10 06:08 PM
And that's the prob as it gets way too hot but I agree w Paul if mileage is a concern (not usually w a 440 ) the heat riser helps and pretty sure that's what's killing mileage on my 318 DD.
Re: Felpro valley pan fiasco [Re: RapidRobert] #880379
12/15/10 06:37 PM
12/15/10 06:37 PM
scratchnfotraction Offline
I remember the... stuff it with 100$$ bills
I have always blocked it running an alum intake and run a heat disapater under the alum carbs on my SB
I will do the same on the BB also
it helps with heat soak and perking gas out of the eddie carbs/vapor lock
cheap fuel today evaps fast and is more for a feul injected engine with high pressure
I have just cut thin peices and used copper rtv to stick them in place,most gaskets that are block will burn thru in a short time
but I have also used a whole tube of the copper rtv to fill the complet void in the intake passage
one thing for sure,the copper rtv will not burn and seals up some warped headers real fast and ezy
I am droping the BB intake by the welding shop at work to have the ports weld shut on my wieand intake this go round
on another note...whats the opinions on that cross over in the intake was to eliminate the H-pipes in the exhst sytem that cars came with back in the day
old timer mechanic said that mopar killed 2 birds with one stone
adds heat for fast warm up and fuel atomazation and does the same thing the H-pipe did to = out/help scavage the back pressure/exhast pulse on #3 and #6 cyls or #4 and #5 cyls
I know I can hear a differance in the glass packs tone/sound with it open or blocked idling at 850 rpms..closed has more deep tone and poping
I think he is but then again what do I know
Re: Felpro valley pan fiasco [Re: RapidRobert] #880380
12/15/10 06:38 PM
12/15/10 06:38 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
FWIW, out of three 318s I've had, all 3 have had blocked passages, one of them did it to me twice. Never had a bigblock plug the passage, and I've had lots more bigblocks over the years.
Re: Felpro valley pan fiasco [Re: scratchnfotraction] #880381
12/15/10 06:43 PM
12/15/10 06:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used one of the FelPro valley pans with the blocked crossover. That cost me a turbocharger.
The little holes were stamped but not punched out. One of the little pieces blew out of the pan and into the exhaust. It ended up getting folded in half and shoved into a turbo jsut far enough to chew up the compressor wheel.
Thanks FelPro!
- Stu Harmon
Re: Felpro valley pan fiasco [Re: scratchnfotraction] #880382
12/15/10 06:58 PM
12/15/10 06:58 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I'm not saying the old guy's right on the reason, but he's right that there can be sound tuning effects.
Back when I was trying to solve some heatsoak problems, I tried a blocked crossover on one of my cars that has an X-pipe. At somewhere around 2500 rpm I got an **awfull** exhaust resonance, so bad that I could hardly drive the car thru the neighborhood. It only lasted a few hundred RPM, but it was loud, and sounded like 2 Hondas fighting inside a metal shed. Should've videotaped it for posterity and youtube.
Re: Felpro valley pan fiasco [Re: scratchnfotraction] #880383
12/15/10 07:35 PM
12/15/10 07:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't know about that because the 440 4bbl and 6pk cars in 70/71 had H pipes and the crossover in the intake .
Re: Felpro valley pan fiasco [Re: JohnRR] #880384
12/15/10 08:04 PM
12/15/10 08:04 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Previous owner or before filled the heads with silicone. Seemed to work. I just left mine to flow.
Re: Felpro valley pan fiasco [Re: Paul_Fancsali] #880385
12/15/10 08:16 PM
12/15/10 08:16 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
If my Chally has Edelbrock Performer (not Performer RPM!) with headers, is 100% street driven in VA where it gets 95F in summer and only occasionally driven in 45F or below in autumn, should I block the crossover or not?
Re: Felpro valley pan fiasco [Re: CJK440] #880386
12/15/10 08:23 PM
12/15/10 08:23 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
LOL! Burned the crap out of my clearcoat! No heat riser.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Felpro valley pan fiasco [Re: CUUDAK] #880387
12/15/10 08:30 PM
12/15/10 08:30 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Those d#mn Chrysler engineers didn't know what they were doing when they left all those crossover's open.Look at the millions of motors they screwed up. :whistling
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880388
12/15/10 08:40 PM
12/15/10 08:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you are not using the heat well choke thermostat for the choke i would , no matter what those chrysler engineers think .
On the other hand if you have a smog era smallblock and the intake has never been off you are all set as the chrysler engineers designed those engines with a self blocking heat riser port ...
Re: Felpro valley pan fiasco [Re: Fury Fan] #880389
12/15/10 10:10 PM
12/15/10 10:10 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I got feed up ordeing valley pans and getting the wrong one localy the crossover port is hour glass shaped so the epxoy can not fall in and last I checked my exhaust pushes gasses out never sucks in
But if it does fail I promise you guys will be the first to know
Re: Felpro valley pan fiasco [Re: sturmenater] #880390
12/16/10 01:24 AM
12/16/10 01:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would think that if the heat rised is operating properly it's going to PUSH the gases from the restricted passenger side to the unrestricted drivers side .
Re: Felpro valley pan fiasco [Re: Kern Dog] #880391
12/16/10 01:55 AM
12/16/10 01:55 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
This sort of stuff actually happens!
I read that Mopar Performance had a run of Big Block camshafts that were incorrectly labled and shipped. Imagine that you buy a 440 Magnum resto cam and end up with a 528 solid. Who takes the time to actually measure cam lobes? How many guys degree in their cams?
That happened to me. Thankfully my engine builder (Bob @ outrageouslyvintage.com) double checks everything and picked up on this error. I can imagine the clatter and disappointment I would have gone through upon first firing up a newly rebuilt engine.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880392
12/17/10 11:55 PM
12/17/10 11:55 PM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
I would
69 Charger RT
Page 2 of 3 1 2 3
