Page 1 of 3 1 2 3
Felpro valley pan fiasco #880353
12/14/10 11:59 PM
12/14/10 11:59 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I tried to order a Felpro 1214 (383-400 valley pan with crossover blocked). Jegs sent me one - I opened it, and the crossover wasn't blocked. I sent it back and asked for the right one. They worked with Felpro and determined somehow that Felpro made a mistake and there are dozens of them out there like this! They opened all the ones they had and every one had the same problem! They couldn't find a correct one to send me so they refunded my money.
If I try to order one locally I'll probably find the same problem! Any ideas?
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880354
12/15/10 12:05 AM
12/15/10 12:05 AM
IN
ahy Offline
ahy  Offline
IN
I'd try another vendor - the local parts store or Mancini. They may have a lot with correct configuration.
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880355
12/15/10 12:07 AM
12/15/10 12:07 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
call felpro and tell them the problem and ask them to send the correct one to summit for you or direct to you !
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880356
12/15/10 12:10 AM
12/15/10 12:10 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
There should have been 2 blockoff pieces made of the same material in the box!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Felpro valley pan fiasco [Re: ahy] #880357
12/15/10 12:12 AM
12/15/10 12:12 AM
If your pressed for time you could solder in a piece of sheet metal onto the valley pan to cover the heat riser opening(s). Just make sure you dont fab something too thick which'll hold the intake up. Not likely but just a heads up
Re: Felpro valley pan fiasco [Re: CUUDAK] #880358
12/15/10 12:23 AM
12/15/10 12:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Never seen one like that , I have that gasket and it's solid across the heat riser port.
Re: Felpro valley pan fiasco [Re: JohnRR] #880359
12/15/10 12:33 AM
12/15/10 12:33 AM
I did, way back (decades) & I'm thinking it was Felpro but wouldn't swear to it and might not even be available
Re: Felpro valley pan fiasco [Re: RapidRobert] #880360
12/15/10 01:02 AM
12/15/10 01:02 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This sort of stuff actually happens!
I read that Mopar Performance had a run of Big Block camshafts that were incorrectly labled and shipped. Imagine that you buy a 440 Magnum resto cam and end up with a 528 solid. Who takes the time to actually measure cam lobes? How many guys degree in their cams?
Re: Felpro valley pan fiasco [Re: RapidRobert] #880361
12/15/10 01:36 AM
12/15/10 01:36 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Yep! Felpro... I purchased one a couple of years ago from Napa. Could have been old stock?? But it did have 2 pieces that plugged the heatriser ports.
Re: Felpro valley pan fiasco [Re: CUUDAK] #880362
12/15/10 01:56 AM
12/15/10 01:56 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i got one of those about 2-3 years ago, and the plates that come with the valley pan are way too thick. lucky my current heads don't have the heat crossover.
Re: Felpro valley pan fiasco [Re: dirtybee] #880363
12/15/10 02:01 AM
12/15/10 02:01 AM
cut 2 pieces out of your old valley pan. It'd be the right thickness and the right material
Re: Felpro valley pan fiasco [Re: RapidRobert] #880364
12/15/10 02:09 AM
12/15/10 02:09 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Agreed!!
Re: Felpro valley pan fiasco [Re: CUUDAK] #880365
12/15/10 03:00 AM
12/15/10 03:00 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
why not just seal the hole in the block, with some jb weld, or plastic steel, and be done with it? then, it doesnt matter what gasket comes out of the box...
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880366
12/15/10 10:06 AM
12/15/10 10:06 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
(Jegs)...worked with Felpro and determined somehow that Felpro made a mistake and there are dozens of them out there like this!
I just ran into the same problem at Summit with a Zoom clutch kit. The model Zoom I ordered was supposed to be diagphram P.P. and I received a 3-finger. They opened all their inventory - same thing. Hat's off to Summit for immediately rectifying the problem no questions asked, but, it was an extra hassle I didn't need.
Re: Felpro valley pan fiasco [Re: dirtybee] #880367
12/15/10 10:58 AM
12/15/10 10:58 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
That was a Mickey Mouse deal offered through Mopar Perfomance some time back. Useless as titts on a bull.
MB
Re: Felpro valley pan fiasco [Re: HPMike] #880368
12/15/10 12:06 PM
12/15/10 12:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mike FelPro made them with the 2 pieces also.I had one and returned it and got the one with the blocks made into it.I even had one that had the plates made into it that came with the 2 pieces also in the package.They are probally laying around here somewhere.Rocky
Chrysler Firepower
Re: Felpro valley pan fiasco [Re: ahy] #880369
12/15/10 01:28 PM
12/15/10 01:28 PM
Orange County, CA
Mike H Offline
Mike H  Offline
Orange County, CA
Just curious, what is the purpose of blocking the heat crossover passages?
Re: Felpro valley pan fiasco [Re: Mike H] #880370
12/15/10 01:32 PM
12/15/10 01:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It keeps the intake cooler for better fuel mix.
Re: Felpro valley pan fiasco [Re: stumpy] #880371
12/15/10 05:06 PM
12/15/10 05:06 PM
P
Paul_Fancsali Offline
P
If you run the car at all in cool weather or on the street I would leave it open. Cars run better warmer then too cold
Re: Felpro valley pan fiasco [Re: Moparmaniacc] #880372
12/15/10 05:31 PM
12/15/10 05:31 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
You could always just have a small plate WELDED INTO the crossover port.
Page 1 of 3 1 2 3
