Re: Felpro valley pan fiasco
[Re: Moparmaniacc]
#880356
12/15/10 12:10 AM
12/15/10 12:10 AM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
There should have been 2 blockoff pieces made of the same material in the box!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: ahy]
#880357
12/15/10 12:12 AM
12/15/10 12:12 AM
RapidRobert
If your pressed for time you could solder in a piece of sheet metal onto the valley pan to cover the heat riser opening(s). Just make sure you dont fab something too thick which'll hold the intake up. Not likely but just a heads up
[Re: CUUDAK]
#880358
12/15/10 12:23 AM
12/15/10 12:23 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Never seen one like that , I have that gasket and it's solid across the heat riser port.
[Re: CUUDAK]
#880362
12/15/10 01:56 AM
12/15/10 01:56 AM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
I did, way back (decades) & I'm thinking it was Felpro but wouldn't swear to it and might not even be available
Yep! Felpro... I purchased one a couple of years ago from Napa. Could have been old stock?? But it did have 2 pieces that plugged the heatriser ports.
i got one of those about 2-3 years ago, and the plates that come with the valley pan are way too thick. lucky my current heads don't have the heat crossover.
[Re: dirtybee]
#880363
12/15/10 02:01 AM
12/15/10 02:01 AM
RapidRobert
cut 2 pieces out of your old valley pan. It'd be the right thickness and the right material
[Re: Moparmaniacc]
#880366
12/15/10 10:06 AM
12/15/10 10:06 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
(Jegs)...worked with Felpro and determined somehow that Felpro made a mistake and there are dozens of them out there like this!
I just ran into the same problem at Summit with a Zoom clutch kit. The model Zoom I ordered was supposed to be diagphram P.P. and I received a 3-finger. They opened all their inventory - same thing. Hat's off to Summit for immediately rectifying the problem no questions asked, but, it was an extra hassle I didn't need.
[Re: dirtybee]
#880367
12/15/10 10:58 AM
12/15/10 10:58 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
That was a Mickey Mouse deal offered through Mopar Perfomance some time back. Useless as titts on a bull.
MB
[Re: HPMike]
#880368
12/15/10 12:06 PM
12/15/10 12:06 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Mike FelPro made them with the 2 pieces also.I had one and returned it and got the one with the blocks made into it.I even had one that had the plates made into it that came with the 2 pieces also in the package.They are probally laying around here somewhere.Rocky
Chrysler Firepower
