'05 Neon "Oil" Lamp #879715
12/14/10 10:53 AM
12/14/10 10:53 AM
North of the Motor City
DartGTDan Offline OP
My daily driver 2005 Neon SE (60,000 miles) has an issue with the oil lamp coming on when first started. Oil capacity is full and clean (even at the 3000 mile oil change). It seems to happen more regularly now that it is COLD in the mornings. After a shut down and restart the lamp goes out. Bad sensor/switch? Any ideas?
Re: '05 Neon "Oil" Lamp [Re: DartGTDan] #879716
12/14/10 01:54 PM
12/14/10 01:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Might be the switch.Then it could be the pump not putting enough pressure to it.Id change it as they are cheap.That or if you have a mechanical gauge test it.Thats the best solution.Rocky
Chrysler Firepower
Re: '05 Neon "Oil" Lamp [Re: therocks] #879717
12/14/10 02:08 PM
12/14/10 02:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
try a new oil pressure switch first, also clean the the plug on connector
Re: '05 Neon "Oil" Lamp [Re: DartGTDan] #879718
12/14/10 07:42 PM
12/14/10 07:42 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
My '05 Neon does the same thing since last winter. Always on the first startup.Rest of the day its fine
Re: '05 Neon "Oil" Lamp [Re: formula_s] #879719
12/14/10 11:11 PM
12/14/10 11:11 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
my 97 pressure switch died, I'd replace the switch
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: '05 Neon "Oil" Lamp [Re: FurryStump] #879720
12/14/10 11:43 PM
12/14/10 11:43 PM
Athens,Ga
mjk5thave Offline
mjk5thave  Offline
Athens,Ga
Its the switch. Did mine last week boy what fun to get to oh switch is around 12 to 20 dollars depends on where you get it
Re: '05 Neon "Oil" Lamp [Re: DartGTDan] #879721
12/17/10 12:45 PM
12/17/10 12:45 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
My daughter's 04 had the same problem. Changed the sender and it was good for about 8 months.
It just started doing it again so I guess it need's to be replaced again but thinking of putting in a mechanical gauge. On a different note regarding Neon's, her's will stall on occasion when she turns her defroster on. Of course I have not been able to get it to do it when I try. It started shortly after I replaced the eng. cooling fan assy. with a new one from NAPA. Any Idea's?
Re: '05 Neon "Oil" Lamp [Re: therocks] #879722
12/17/10 03:00 PM
12/17/10 03:00 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
One more vote for the switch
Kevin
Re: '05 Neon "Oil" Lamp [Re: JCCuda] #879723
12/18/10 10:07 PM
12/18/10 10:07 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Her A/C compressor clutch is either on it's way out or the compressor is close to being locked up. When the defrost is turned in, the A/C turns on, and it'll kill the engine if the comp. is locked up. Unplug the power to the comp. and fix it in spring.
