Re: '05 Neon "Oil" Lamp
[Re: DartGTDan]
#879716
12/14/10 01:54 PM
12/14/10 01:54 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Might be the switch.Then it could be the pump not putting enough pressure to it.Id change it as they are cheap.That or if you have a mechanical gauge test it.Thats the best solution.Rocky
Chrysler Firepower
[Re: JCCuda]
#879723
12/18/10 10:07 PM
12/18/10 10:07 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
On a different note regarding Neon's, her's will stall on occasion when she turns her defroster on. Of course I have not been able to get it to do it when I try. It started shortly after I replaced the eng. cooling fan assy. with a new one from NAPA. Any Idea's?
Her A/C compressor clutch is either on it's way out or the compressor is close to being locked up. When the defrost is turned in, the A/C turns on, and it'll kill the engine if the comp. is locked up. Unplug the power to the comp. and fix it in spring.
