check engine light on 03 Neon- turn off? #878218
12/12/10 02:42 PM
12/12/10 02:42 PM
md
mopars4ever Offline OP
md
I was wondering how to turn the check engine light off on my 03 Neon. The t-stat was bad and I replaced it but the light is still on. Will disconnecting the battery work? Will it go off on its own. I don`t think Autozone will turn them off. By the way the t-stat was broke in half. I guess years of opening and closing finally took it`s toll on it.
Re: check engine light on 03 Neon- turn off? [Re: mopars4ever] #878219
12/12/10 03:11 PM
12/12/10 03:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You should be able to disconnect the battery cable for about 5 minutes and it may reset.
Re: check engine light on 03 Neon- turn off? [Re: mopars4ever] #878220
12/12/10 04:40 PM
12/12/10 04:40 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
How do you know the check engine light is for the thermostat? Check engine code is ON-OFF-ON-OFF-ON with the key. Where the mileage is usually displayed will be where the type of problem will be displayed. Sometimes it takes a while driving before the check engine light goes off.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: check engine light on 03 Neon- turn off? [Re: Junky] #878221
12/12/10 07:55 PM
12/12/10 07:55 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
www.neons.org , Second Gen section.
Re: check engine light on 03 Neon- turn off? [Re: stumpy] #878222
12/12/10 08:26 PM
12/12/10 08:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I agree. That is what some dealerships do behind the shop wall while you wait and they charge full shop labor to do it.
Re: check engine light on 03 Neon- turn off? [Re: MoparforLife] #878223
12/12/10 10:04 PM
12/12/10 10:04 PM
md
md
Because I took the car to autozone and they ran a scan and that code came up.
Re: check engine light on 03 Neon- turn off? [Re: mopars4ever] #878224
12/12/10 10:10 PM
12/12/10 10:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Auto Zone can turn off the CEL with the same scan tool that they pulled the code with. That way you won't have to reset the clock and radio stations.
Master, again and still
Re: check engine light on 03 Neon- turn off? [Re: MoparforLife] #878225
12/13/10 02:41 AM
12/13/10 02:41 AM
Woodburn Oregon
Two Lane Offline
Two Lane  Offline
Woodburn Oregon
That isn't the correct way to do it. In the early 90's (up to 95) computer vehicles that was Ok to do. The newer OBD 2 type vehicles I don't recommend that. The transmission computers have to relearn a new drive cycle and it'll crate havoc if you do that over and over. Go to Schucks or Auto Zone have them clear the code.
"Do you know why I stopped you?"- "No" - "Your license plate was laid down"- "Oh that,- that only happens when I Floor it"
