External Pickup #873538
12/07/10 12:23 PM
12/07/10 12:23 PM
Northwest Chicago Suburb
DaDart Offline OP
DaDart  Offline OP
What's the best way to seal the external pickup to the pan? Looked around and couldn't find any post on this so I figured I ask.
3 Darts and a Ram
Re: External Pickup [Re: DaDart] #873539
12/07/10 12:41 PM
12/07/10 12:41 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I have a single line external pickup that started to leak. I took it apart and installed a viton "O" ring on the inside of the pan were the fitting connects to the pickup. Tightened it all up with a little high temp silicone around the threads. Leak stopped. Just my solution.
Re: External Pickup [Re: maximus] #873540
12/07/10 12:50 PM
12/07/10 12:50 PM
an8sec70cuda Offline
I use silicone. I bought the DMI washer and O-ring kit, but it still leaked and I had to massage the washers b/c they didn't fit over the fittings.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: External Pickup [Re: an8sec70cuda] #873541
12/07/10 10:26 PM
12/07/10 10:26 PM
DaDart Offline OP
DaDart  Offline OP
Thanks. I don't think you can get the DMI kit anymore but hoping to get this installed without leaks. Anyone else have any ideas?
3 Darts and a Ram
Re: External Pickup [Re: DaDart] #873542
12/07/10 10:49 PM
12/07/10 10:49 PM
AndyF Online content
AndyF  Online Content
I use bulkhead fittings with washers. That seems to work the best.
Re: External Pickup [Re: AndyF] #873543
12/07/10 10:54 PM
12/07/10 10:54 PM
I use the stock 90 AN bulkead fittings that come with the dual line Milidon swinging pickup kits I do now use two washers and two O rings on fitting like AndyF pictues shows on his fittings
Re: External Pickup [Re: Cab_Burge] #873544
12/08/10 12:42 AM
12/08/10 12:42 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
What you need are thread sealing washers. P/N is 750-0002-7/8 (Parker) for size 10 bulkhead fittings.
