those of you running Cometics #872291
12/05/10 07:51 PM
12/05/10 07:51 PM
Kissimmee Fl.
dusturbd340W5 Offline OP
Kissimmee Fl.
did you retorque them after a heat cycle?
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: those of you running Cometics [Re: dusturbd340W5] #872292
12/05/10 08:11 PM
12/05/10 08:11 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nope.
too hard on a BB.
been running 2 years now no worries
plus how often do i retorque a modern motor,never because often you can't.
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: those of you running Cometics [Re: tex013] #872293
12/05/10 08:18 PM
12/05/10 08:18 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
nope.
too hard on a BB.
Tex
My 451 CID use Cometics
No retorque the best Gaskets on the Market...
Re: those of you running Cometics [Re: STROKIE] #872294
12/05/10 08:30 PM
12/05/10 08:30 PM
Mo.
racerx Offline
racerx  Offline
Mo.
nope.
too hard on a BB.
Tex
x2
Re: those of you running Cometics [Re: dusturbd340W5] #872295
12/05/10 08:32 PM
12/05/10 08:32 PM
I don't but I learned to make sure the block deck and head surfaces are very smooth before using them, don't ask me how I know Make sure and get the RA numbers(measured surface finish numbers ) and use them on the finish on your heads and block to make sure the gaskets seal properly
Re: those of you running Cometics [Re: Cab_Burge] #872296
12/05/10 08:39 PM
12/05/10 08:39 PM
Kissimmee Fl.
Kissimmee Fl.
my machine shop is familiar with cometics and he knew that was what we would be running when he did the surface work so we should be good
Re: those of you running Cometics [Re: dusturbd340W5] #872297
12/05/10 08:41 PM
12/05/10 08:41 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Not to hijack the post but has anyone re used them
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: those of you running Cometics [Re: 65dragnet] #872298
12/05/10 08:42 PM
12/05/10 08:42 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
All the time.
Re: those of you running Cometics [Re: HPMike] #872299
12/05/10 08:54 PM
12/05/10 08:54 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I had to double them, due to bad surface,
never a problem after that
Re: those of you running Cometics [Re: 65dragnet] #872300
12/05/10 11:00 PM
12/05/10 11:00 PM
I have on three or four different motors, B with iron heads, RB w/alumimun heads and 426 hemis with both types of heads, iron and alumimun
Re: those of you running Cometics [Re: Cab_Burge] #872301
12/05/10 11:21 PM
12/05/10 11:21 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I have reused the set on my 556 twice. On my previous 511 I reused the set 5 times, and they are still going. I sold the 511 to my friend.
Re: those of you running Cometics [Re: Twin Turbo Mower] #872302
12/05/10 11:26 PM
12/05/10 11:26 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Just like a timex take a lickin' and keep on tickin'. I will only us Cometic PERIOD!!!
Re: those of you running Cometics [Re: Biginchmopar] #872303
12/06/10 10:42 AM
12/06/10 10:42 AM
an8sec70cuda Offline
I always retorque them and have reused them before. No problems.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: those of you running Cometics [Re: an8sec70cuda] #872304
12/06/10 10:48 AM
12/06/10 10:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We reuse them and when we do we seperate all but one rivit fanning the layers and spray them with Permatex copper spray on all the layers,let it get tacky and install.we generally allow it to set a few days at final torque and recheck.
Re: those of you running Cometics [Re: Cab_Burge] #872305
12/06/10 11:16 AM
12/06/10 11:16 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i ruined a fresh build do to a water leak that wasnt noticed and the car sat for awhile with water in the cylenders,had the block resurfaced and no more probs.
Re: those of you running Cometics [Re: 65dragnet] #872306
12/06/10 02:59 PM
12/06/10 02:59 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
9 times before we noticed a leak.
