those of you running Cometics
#872291
12/05/10 07:51 PM
12/05/10 07:51 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
did you retorque them after a heat cycle?
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: those of you running Cometics
[Re: dusturbd340W5]
#872292
12/05/10 08:11 PM
12/05/10 08:11 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
nope. too hard on a BB. been running 2 years now no worries plus how often do i retorque a modern motor,never because often you can't.
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#872293
12/05/10 08:18 PM
12/05/10 08:18 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
Tex
My 451 CID use Cometics No retorque the best Gaskets on the Market...
[Re: STROKIE]
#872294
12/05/10 08:30 PM
12/05/10 08:30 PM
Posts: 4,066 Mo.
racerx
Mo.
Tex
x2
[Re: 65dragnet]
#872298
12/05/10 08:42 PM
12/05/10 08:42 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Not to hijack the post but has anyone re used them
All the time.
[Re: Biginchmopar]
#872303
12/06/10 10:42 AM
12/06/10 10:42 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I always retorque them and have reused them before. No problems.
[Re: Cab_Burge]
#872305
12/06/10 11:16 AM
12/06/10 11:16 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I don't but I learned to make sure the block deck and head surfaces are very smooth before using them, don't ask me how I know Make sure and get the RA numbers(measured surface finish numbers ) and use them on the finish on your heads and block to make sure the gaskets seal properly
i ruined a fresh build do to a water leak that wasnt noticed and the car sat for awhile with water in the cylenders,had the block resurfaced and no more probs.
[Re: 65dragnet]
#872306
12/06/10 02:59 PM
12/06/10 02:59 PM
Posts: 4,647 aotearoa
rebel
aotearoa
9 times before we noticed a leak.
