Re: Crane Ductile Rocker w/Comp Street Roller
[Re: SILVER67]
#870193
12/03/10 12:04 PM
12/03/10 12:04 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
That quite a bit of spring pressure. I have run them to about 350 lbs open with solid flat tappets. But your talking about 40% more pressure overall compared to a solid flat cam.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: SILVER67]
#870194
12/03/10 01:02 PM
12/03/10 01:02 PM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
Hey Guys,
Have any of you guys had any luck with some of the milder "street" solid rollers and the Crane Iron rockers? Say something like the Lunati .600/.600 VooDoo or the Comp XR292R. Will the Crane iron rockers handle the spring pressure of a street roller? The Comp recomended spring has an open load of 456 pounds. Thanks!
Michael
Michael
I have those two EXACT cams and am deciding which one to run in my 511 RB. (Thinking VooDoo! Got it off Ebay AFTER I had the XR292...) I have Stealth heads with Isky 9205 springs (aprox 190# seat and maybe 475# open), and I sent some original MaxWedge rockers to RAS and had them bronze bushed and fitted to my shafts. Well worth the investment for durability and simplicity! RB
[Re: moparts]
#870196
12/03/10 01:41 PM
12/03/10 01:41 PM
Bighead440
What did this cost you?
I called them about doing this, the price was insane, could have bought real race rockers for less
I had the rockers, and I think it was priced per rocker, $7 back then (maybe a year)IIRC. Plus shipping to California of course. Nicely bushed with re-routed oiling and internally grooved. I would rather have these than budget full rollers or higher priced roller-tipped ones that would gall to the shafts under the pressure... RB
[Re: SILVER67]
#870203
12/03/10 04:30 PM
12/03/10 04:30 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I run the iron rockers and my old motor had mopar triple battleship springs and the crane R280 roller, .670 lift, .280 duration, never had any problems and i'm still using the same rockers and shafts. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: SILVER67]
#870206
12/03/10 10:54 PM
12/03/10 10:54 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Michael,
I'll call you Saturday or vica versa..
RIP Monte Smith
