Crane Ductile Rocker w/Comp Street Roller #870192
12/03/10 11:32 AM
12/03/10 11:32 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Hey Guys,
Have any of you guys had any luck with some of the milder "street" solid rollers and the Crane Iron rockers? Say something like the Lunati .600/.600 VooDoo or the Comp XR292R. Will the Crane iron rockers handle the spring pressure of a street roller? The Comp recomended spring has an open load of 456 pounds. Thanks!
Michael
Michael
Re: Crane Ductile Rocker w/Comp Street Roller [Re: SILVER67] #870193
12/03/10 12:04 PM
12/03/10 12:04 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
That quite a bit of spring pressure. I have run them to about 350 lbs open with solid flat tappets. But your talking about 40% more pressure overall compared to a solid flat cam.
Re: Crane Ductile Rocker w/Comp Street Roller [Re: SILVER67] #870194
12/03/10 01:02 PM
12/03/10 01:02 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
Hey Guys,
Michael
Michael
I have those two EXACT cams and am deciding which one to run in my 511 RB. (Thinking VooDoo! Got it off Ebay AFTER I had the XR292...) I have Stealth heads with Isky 9205 springs (aprox 190# seat and maybe 475# open), and I sent some original MaxWedge rockers to RAS and had them bronze bushed and fitted to my shafts. Well worth the investment for durability and simplicity! RB
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Bighead440] #870195
12/03/10 01:30 PM
12/03/10 01:30 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
What did this cost you?
I called them about doing this, the price was insane, could have bought real race rockers for less
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Crane Ductile Rocker w/Comp Street Roller [Re: moparts] #870196
12/03/10 01:41 PM
12/03/10 01:41 PM
Bighead440 Offline
Bighead440  Offline
I had the rockers, and I think it was priced per rocker, $7 back then (maybe a year)IIRC. Plus shipping to California of course. Nicely bushed with re-routed oiling and internally grooved. I would rather have these than budget full rollers or higher priced roller-tipped ones that would gall to the shafts under the pressure... RB
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Bighead440] #870197
12/03/10 01:49 PM
12/03/10 01:49 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
really? Only $7 per rocker? Thats cheap!
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Bighead440] #870198
12/03/10 02:00 PM
12/03/10 02:00 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I was told to bush and blueprint a set of Crane Iron Rockers right around $1000
RAS web site is useless, I saw some posts about having this work do, so I called for pricing
Tom ,
2009 Challenger R/T
Re: Crane Ductile Rocker w/Comp Street Roller [Re: moparts] #870199
12/03/10 02:33 PM
12/03/10 02:33 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I have a set of iskys that were done 10-12 years ago with super thick shafts spacers and hold downs. Back then it was $450 or so. My set has been street driven and raced on several cars and are still like new. Mine were also changed to 1.6 when they were done. It was a lot of money but for long term service I think they will be hard to beat.
Getting old just means you were smarter than some and luckier than others.
Re: Crane Ductile Rocker w/Comp Street Roller [Re: dannysbee] #870200
12/03/10 02:58 PM
12/03/10 02:58 PM
Bighead440 Offline
Bighead440  Offline
I provided my own Crane shafts and Crower adjusters, so I guess I could have bought some bushed PRW roller tips or maybe some Crane golds new for what I have in these, but not like Harland Sharps or anything like that. Prolly have less than $300 in the whole deal but I feel good about them for the street. I had two sets of Iskys done previously with RAS supplying the new adjusters, shafts and hold downs, and I think it was $400+ per setup, but NICE stuff with zero problems. RB
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Bighead440] #870201
12/03/10 03:12 PM
12/03/10 03:12 PM
RAS will change the ratio, repalce the adjusters with good ones repair the tips and bush the rockers for less than you can buy a decent new one like the crane aluminum or comparable non bushed roller tip rockers I had them do several sets 5 or 6 years ago, call them for a exact quote. Quality is never cheap, you get what you pay for, if your lucky AND don't pi$$ of the owners
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Cab_Burge] #870202
12/03/10 04:18 PM
12/03/10 04:18 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Some decent feedback here. Trying to weigh my options. I have a brand new set of the Crane Iron rockers and HD MP shafts. I'm thinking of stepping up my camshaft a bit for the rebuild I have in store..
Can't decide if I should bush them (RAS) or sell and buy HS....
Michael
Re: Crane Ductile Rocker w/Comp Street Roller [Re: SILVER67] #870203
12/03/10 04:30 PM
12/03/10 04:30 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I run the iron rockers and my old motor had mopar triple battleship springs and the crane R280 roller, .670 lift, .280 duration, never had any problems and i'm still using the same rockers and shafts.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Crane Ductile Rocker w/Comp Street Roller [Re: moparts] #870204
12/03/10 09:45 PM
12/03/10 09:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Tom I sent a set of Isky iron rockers to RAS and got them bushed,trimmed,new hardware,new shafts,all for under $600.00 Granted I could have had the entire RAS rocker set-up for a few hundred more but I really like the Isky rockers
They fit and work perfectly
Gus
64 Plymouth Savoy
Dana 60
Re: Crane Ductile Rocker w/Comp Street Roller [Re: fourgearsavoy] #870205
12/03/10 10:26 PM
12/03/10 10:26 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I use them...stock...Crane hyd roller with 530 lift...don't know the seat pressure...about 3 years now ..no problem
Re: Crane Ductile Rocker w/Comp Street Roller [Re: SILVER67] #870206
12/03/10 10:54 PM
12/03/10 10:54 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Michael,
I'll call you Saturday or vica versa..
RIP Monte Smith
Re: Crane Ductile Rocker w/Comp Street Roller [Re: SILVER67] #870207
12/04/10 02:17 AM
12/04/10 02:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I wouldn`t ever consider bushing and correcting those pieces.........Buy(save to buy)at least the HS`s w/hardened shafts, spacers stud em and you`re good to go for many trouble free years. I`m going on 6+ years w/LOTS of street miles and a few hundred passes and all is well. I don`t skimp on my car......maybe that`s why it doesn`t break and has never let me down or left me stranded.
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Thumperdart] #870208
12/04/10 07:57 PM
12/04/10 07:57 PM
Rittman Ohio
Rittman Ohio
For the record I have seen more broken H.S. rockers than iron units
Gus
64 Plymouth Savoy
Dana 60
Re: Crane Ductile Rocker w/Comp Street Roller [Re: fourgearsavoy] #870209
12/04/10 09:12 PM
12/04/10 09:12 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
I have seen a few HS's broken. Still looking to see if the iron units break.
Michael
Re: Crane Ductile Rocker w/Comp Street Roller [Re: SILVER67] #870210
12/04/10 09:20 PM
12/04/10 09:20 PM
Locomotion Offline
Locomotion  Offline
I broke 2 Cranes this year after many years of use. But they were "relieved" for spring clearance and I left a sharp cut instead of blending it.
I ran Harland Sharps on a W-2 360 for many years with no problems. A few tip rollers may have started to get worn. But the only ones I recall seeing broken were ones cut for spring clearance.
Re: Crane Ductile Rocker w/Comp Street Roller [Re: Locomotion] #870211
12/04/10 10:31 PM
12/04/10 10:31 PM
Rittman Ohio
Rittman Ohio
I really think the RAS 440 MAX rockers are the best rockers on the market second only to Jessel for strength and reliability
Gus
64 Plymouth Savoy
Dana 60
