AMD full floor pans come with gas pedal holes drilled? #869761
12/02/10 06:44 PM
12/02/10 06:44 PM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys!
I had the full front floor pan in my '69 Super Bee replaced with an AMD piece. I also had the floors coated with Lizard Skin heat shield and sound deadener.
The body shop taped off all the holes before spaying the Lizard Skin, and since it goes on pretty thick, I'm having a hard time finding the ones for the gas pedal, and don't want to start digging around if they aren't even there.
Thanks!
Paul
'69 Super Bee 383 EFI Turbo
Re: AMD full floor pans come with gas pedal holes drilled? [Re: Black_Bee] #869762
12/02/10 07:51 PM
12/02/10 07:51 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
I installed a AMD floor in my 69 Charger. I had to drill the holes for the pedal.
Re: AMD full floor pans come with gas pedal holes drilled? [Re: 1hot68] #869763
12/02/10 08:59 PM
12/02/10 08:59 PM
BC, Canada
BC, Canada
Thanks for the info!
Paul
Re: AMD full floor pans come with gas pedal holes drilled? [Re: Black_Bee] #869764
12/03/10 08:38 PM
12/03/10 08:38 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Same here. Also applies to the dimmer switch holes, you'll need to drill those too.
Steve
www.clarkclassic.com
Re: AMD full floor pans come with gas pedal holes drilled? [Re: Black_Bee] #869765
12/03/10 10:13 PM
12/03/10 10:13 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I would try looking from the bottom.
I can't afford this. mark
Re: AMD full floor pans come with gas pedal holes drilled? [Re: a12superbee] #869766
12/04/10 11:23 AM
12/04/10 11:23 AM
Chicagoland
cudastruction Offline
Chicagoland
Yeah, I am not sure about that piece but sometimes there are dimples where you might need to drill a hole.
Re: AMD full floor pans come with gas pedal holes drilled? [Re: cudastruction] #869767
12/05/10 01:07 PM
12/05/10 01:07 PM
Greenville, N.C.
Greenville, N.C.
No dimples on that pan.
Re: AMD full floor pans come with gas pedal holes drilled? [Re: a12superbee] #869768
12/05/10 07:19 PM
12/05/10 07:19 PM
BC, Canada
BC, Canada
I tried looking from the bottom too, but it is covered in new thick undercoat too!
Paul
