Page 2 of 81 1 2 3 4 80 81
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867759
12/01/10 05:27 PM
12/01/10 05:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jamie what are you going to use for a shifter?
That looks sweet, I'm in for one especially with a change in rear gears to 4:30's come spring time .
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867760
12/01/10 05:34 PM
12/01/10 05:34 PM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
John,
Thanks! We made a custom 5 spd HURST shifter and made linkage to clear crossmember and floor. I don't have any pics with the shifter and linkage on. I will take pics at PRI and post them when we get back.
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: New Passon Performance 5 Speed update [Re: DaytonaTurbo] #867761
12/01/10 05:51 PM
12/01/10 05:51 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Are the 3 different retainer OD's going to be available for this unit as well?
2 Demons...no, not my kids!
Re: New Passon Performance 5 Speed update [Re: 4speeds4me] #867762
12/01/10 05:56 PM
12/01/10 05:56 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
We are not using an integrated shifter. If you do that, you are just gonna have another tremec that doesn't fit. It isn't a stock shifter because it is 5 speeds. It is stock arrangement. The shifter and linkage will be part of the package when the transmission is purchased. We are making a 4.35" bearing retainer and a 4.80" bearing retainer. Sorry, no 5.125 OD size. Just not enough call for one. We have an adapter ring available for the 5.125" application though.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867763
12/01/10 07:22 PM
12/01/10 07:22 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Hey look at that... Thanks jbc426. I'll get the hang of this computer thing yet! Forgive the bearing retainer bolts missing and sidecover bolts missing. Note the 5 bolt bearing retainer. That covers a tapered roller bearing with an O Ring seal. We went 5 bolt for increased bearing load capacity.
Wow! Beautiful work. I can hardly wait to "shake it on down into overdrive" with my 3.54's and cruise at 70mph to Hot August Nights or Mopars at the Strip in Las Vegas.
Re: New Passon Performance 5 Speed update [Re: jbc426] #867764
12/01/10 09:04 PM
12/01/10 09:04 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Looks great, Jamie! I am in Florida right now but I probably won't make PRI this year, if I do I will look you up!
JB Rhinehart, Realist
A-Body's RULE!
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867765
12/01/10 10:17 PM
12/01/10 10:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Once again an awesome product from Passon Performance
So are 1-4 in the side cover with fifth and reverse on the lower(reverse)selector shaft like a Nash/Richmond box?
Gus
64 Plymouth Savoy
Dana 60
Re: New Passon Performance 5 Speed update [Re: Jim_Lusk] #867766
12/01/10 10:24 PM
12/01/10 10:24 PM
Eastern ohio
Alexdodge Offline
Alexdodge  Offline
Eastern ohio
What, no 23 spline????
Re: New Passon Performance 5 Speed update [Re: Alexdodge] #867767
12/01/10 10:44 PM
12/01/10 10:44 PM
Rittman Ohio
Rittman Ohio
Why would you do that??? They built the 18 spline because the 23 spline wouldn't hold up to the power,weight,and traction.
Gus
64 Plymouth Savoy
Dana 60
Re: New Passon Performance 5 Speed update [Re: fourgearsavoy] #867768
12/01/10 10:56 PM
12/01/10 10:56 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Gus
But that was with 40? year old materials, I would think today that would be less of an issue, and Passon runs a business that caters to customer driven demands, so if there really is enough demand, why not a 23 spline in the future?
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867769
12/01/10 11:05 PM
12/01/10 11:05 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
I really can't answer anything about the CF clutches. In my opinion, they are 2nd or 3rd choice. I never liked them. Just my opinion though. To each his own.
Re: New Passon Performance 5 Speed update [Re: jcc] #867770
12/01/10 11:13 PM
12/01/10 11:13 PM
Rittman Ohio
Rittman Ohio
Gus
Did you ever compare the size of the teeth on a 23 spline to an 18 spline gear? The thickness at the root of the tooth is much larger and less prone to failure.The diameter of the drive pinion is also able to take more abuse as well.
Gus
64 Plymouth Savoy
Dana 60
Re: New Passon Performance 5 Speed update [Re: fourgearsavoy] #867771
12/01/10 11:25 PM
12/01/10 11:25 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Finally a 5 speed option that doesn't require hacking up the car, and coming from a vendor with a great reputation too. I know they won't be cheap but if the price comes in reasonable the demand will be very high.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867772
12/01/10 11:31 PM
12/01/10 11:31 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
So the front bearing will be a 307 or something similar?...or will they be tapered rollers? What rear bearing is in there?
Re: New Passon Performance 5 Speed update [Re: 69Cuda340S] #867773
12/01/10 11:32 PM
12/01/10 11:32 PM
dart1962_440 Offline
Any info available on the ratios for each gear?
Re: New Passon Performance 5 Speed update [Re: dart1962_440] #867774
12/02/10 12:17 AM
12/02/10 12:17 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I just want to know who is testing it
Re: New Passon Performance 5 Speed update [Re: scatpacktom] #867775
12/02/10 12:20 AM
12/02/10 12:20 AM
4speeds4me Offline
4speeds4me  Offline
Herb McCandless? I'd get in line for that job.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867776
12/02/10 12:22 AM
12/02/10 12:22 AM
AndyF Online content
AndyF  Online Content
Looks great Jamie.
Re: New Passon Performance 5 Speed update [Re: AndyF] #867777
12/02/10 01:14 AM
12/02/10 01:14 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Very cool. It'll be a while before I can afford something like this, but it is awesome you came up with it. I'm sure it is well worth the wait.
Just curious on weight compared to an old one? I have the 23 spline in my car and could care less if I have to change to 18 spline. It just plain makes sense to use the 18 spline. I'm sure his investment costs are already high, so maybe if these sell well he will switch, but once again, why settle for second best.
Can't wait to Wonder if I'll bust my knuckles w/ my bench seat
Re: New Passon Performance 5 Speed update [Re: 68KillerBee] #867778
12/02/10 01:59 AM
12/02/10 01:59 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Very nice looking.
