elect fan useres #867693
12/01/10 12:56 AM
12/01/10 12:56 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
what do you guys use to control your fans.right now mine just stays on all the time,id like it to shut off after i gain speed.
Re: elect fan useres [Re: bonefish] #867694
12/01/10 01:15 AM
12/01/10 01:15 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I use a Spal controller...works perfect for me (with a dual Spal fan setup)
http://www.speedwaymotors.com/Spal-Pulse-Width-Modulated-Fan-Controller,35700.html
Re: elect fan useres [Re: bonefish] #867695
12/01/10 01:15 AM
12/01/10 01:15 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I use a SPAL PWM controller with my ford taurus fan. It turns the fan on and off and varies fan speed with temp. I use them on all the cars I convert to electric fans. http://www.spal-usa.com/fans/automated/accessories/fanpwm.html
Re: elect fan useres [Re: bonefish] #867696
12/01/10 03:14 AM
12/01/10 03:14 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
summit sells kits
Re: elect fan useres [Re: bonefish] #867697
12/01/10 03:45 AM
12/01/10 03:45 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I use the Dakota digital 2 speed fan controller for my Ford Taurus fan in my 72 Challenger with a 512. You can use the gauge sensor you already have installed in the water pump housing and it will turn low and high speed on at the temps you set.
Re: elect fan useres [Re: Boise Chall] #867698
12/01/10 04:11 AM
12/01/10 04:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Just a standard fan control relay. kicks on above 185, shuts off at 170. on the highway, once my temps drop, the fan shuts off.
it'll even cycle off and on in town running in traffic.
just gotta have a thermostat that is at or below the off temp of the controller, otherwise, the thermostat will close and start bringing the temps back up before the fan ever shuts off.
**Photobucket sucks**
Re: elect fan useres [Re: 70Cuda383] #867699
12/01/10 03:20 PM
12/01/10 03:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My Mercedes fan cooled the engine below the thermostat.
I cheated a wee bit on the controller. I used my EFI system to turn it on and off.
- Stu Harmon
Re: elect fan useres [Re: feets] #867700
12/01/10 06:19 PM
12/01/10 06:19 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I was going too as well....but eh...changed my mind
Re: elect fan useres [Re: OzHemi] #867701
12/02/10 12:01 PM
12/02/10 12:01 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
does this work with a mech.guage?
Re: elect fan useres [Re: bonefish] #867702
12/02/10 12:12 PM
12/02/10 12:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Your mechanical gauge will not trigger a fan controller. There are other places to mount a sending unit without giving up your mechanical gauge.
- Stu Harmon
Re: elect fan useres [Re: 70Cuda383] #867703
12/02/10 02:47 PM
12/02/10 02:47 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
Does anyone know who sells just the switch that goes in the WP housing? I don't need the relay, wiring, etc, just the switch. Most everybody seems to list them by model nummber, not on/off temps.
Re: elect fan useres [Re: 440dodge440] #867704
12/02/10 04:07 PM
12/02/10 04:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Buy a factory original part for your car.
- Stu Harmon
Re: elect fan useres [Re: feets] #867705
12/02/10 07:08 PM
12/02/10 07:08 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
And use a sending unit for a gauge, not a light...so you get the variable signal you'll need if using the Spal controller for example.
You just program it to go on and off at what ever temps you want from there.
Re: elect fan useres [Re: bonefish] #867706
12/02/10 09:39 PM
12/02/10 09:39 PM
South East VA
Joel71 Offline
Joel71  Offline
South East VA
Mine is wired hot to a toggle switch. I turn it on when I need it, leave it off when I don't. I can also run it without the car being on at the track to cool it between runs.
Re: elect fan useres [Re: OzHemi] #867707
12/02/10 09:39 PM
12/02/10 09:39 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
im running the mezerie unit and there is only a spot for the mech gage.where do you mount a sensor for the spal unit and what type should i get?
Re: elect fan useres [Re: Joel71] #867708
12/06/10 02:33 PM
12/06/10 02:33 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
This is how mine is set up now....I'd like to use a switch that closes at around 190 and opens around 170. I can use this to trigger the relay and operate the fan....problem is, all of these are sold in kits that have a lot of stuff I don't need....
Re: elect fan useres [Re: bonefish] #867709
12/06/10 05:32 PM
12/06/10 05:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can put the sending unit in the head or intake (small block). If all else fails, go to the hardware store and get some plumbing parts to tee into the fitting and run both the sender and sensor in that hole.
- Stu Harmon
Re: elect fan useres [Re: feets] #867710
12/06/10 09:58 PM
12/06/10 09:58 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have a twin fan set up with separate switches & relays for each fan.They are controlled by my right hand man "MANUEL"
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
