how to pull an alternator pulley?
#866897
11/29/10 11:12 PM
11/29/10 11:12 PM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
sorry 'bout the foul mouth but i just used a clone of the tool shown in the fsm and bent the crap out of my brand new tuff stuff 100 amp alt pulley. my current alt has a 3 inch pulley that i want to use instead of the supplied 2 3/4 'cause of my 3.91's. the actual part where the belt rides is fine but the thick steel lip that the puller grabs is now fubar... what gives? any tips or tricks? thanks in advance. ![](/ubbthreads/images/graemlins/hammer.gif) .....ps... grrrr i'm mad.
Re: how the f@*k to pull an alternator pulley?
[Re: stumpy]
#866899
11/29/10 11:18 PM
11/29/10 11:18 PM
RapidRobert
we need pics! (pulley/tool)
[Re: stumpy]
#866900
11/29/10 11:22 PM
11/29/10 11:22 PM
Posts: 15,487 Florida
scratchnfotraction
best way is to take the alt apart and press the pully off,then press the new one on and put it back together pressing the pully on and the alt together can mess it up the back bearing ![](/ubbthreads/images/graemlins/iagree.gif) no biggie on the pully size and rpm
[Re: scratchnfotraction]
#866901
11/30/10 12:04 AM
11/30/10 12:04 AM
RapidRobert
yes you need to split the case when pressing the new one on (as you need to support the rear of the shaft) but not needed when pulling the old one off as your doing your work on the front side but moot point as the case does need to be split. Still wondering what puller was used to try & get it off
[Re: drew72]
#866907
11/30/10 01:00 AM
11/30/10 01:00 AM
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif) other than looks its still good and still shinny yea I would run it and not worry about that pully as far as juice,i uped mine to a mini alt on my 440 in the sig pic it was a bolt on,,double pully,external regulated,120 amps,smaller/lighter yea thats the correct puller/i was just sayng it looked like the cheapy one for plumbing I have handles ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: how to pull an alternator pulley?
[Re: Snoopy]
#866914
11/30/10 09:50 AM
11/30/10 09:50 AM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
Go to Advanced or Auto Zone.They have the pullers in their loaner tools.Looks like 2 halves that go around the outer flange.There is a sleeve that fits over them and a threaded bolt that goes into a big flat piece.they are easy to pull.Ive done hundreds at work.As said he alt needs to be split to press on although I have pressed a few on without spliting them.Rocky
Chrysler Firepower
[Re: Snoopy]
#866915
11/30/10 10:01 AM
11/30/10 10:01 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
This puller works and it goes on sale all the time for 50% off.
Pulley Remover and Installer Set
Same sort of puller for Federal power steering pump pullies, too...
