how to pull an alternator pulley? #866897
11/29/10 11:12 PM
11/29/10 11:12 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
sorry 'bout the foul mouth but i just used a clone of the tool shown in the fsm and bent the crap out of my brand new tuff stuff 100 amp alt pulley. my current alt has a 3 inch pulley that i want to use instead of the supplied 2 3/4 'cause of my 3.91's. the actual part where the belt rides is fine but the thick steel lip that the puller grabs is now fubar... what gives? any tips or tricks? thanks in advance. .....ps... grrrr i'm mad.
Re: how the f@*k to pull an alternator pulley? [Re: dirtybee] #866898
11/29/10 11:16 PM
11/29/10 11:16 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Still no reason for the language. The pulley would not have made that much difference. It wouldn't have changed the charging rate.
Re: how the f@*k to pull an alternator pulley? [Re: stumpy] #866899
11/29/10 11:18 PM
11/29/10 11:18 PM
we need pics! (pulley/tool)
Re: how the f@*k to pull an alternator pulley? [Re: stumpy] #866900
11/29/10 11:22 PM
11/29/10 11:22 PM
scratchnfotraction Offline
best way is to take the alt apart and press the pully off,then press the new one on and put it back together
pressing the pully on and the alt together can mess it up the back bearing
no biggie on the pully size and rpm
Re: how the f@*k to pull an alternator pulley? [Re: scratchnfotraction] #866901
11/30/10 12:04 AM
11/30/10 12:04 AM
yes you need to split the case when pressing the new one on (as you need to support the rear of the shaft) but not needed when pulling the old one off as your doing your work on the front side but moot point as the case does need to be split. Still wondering what puller was used to try & get it off
Re: how the f@*k to pull an alternator pulley? [Re: RapidRobert] #866902
11/30/10 12:09 AM
11/30/10 12:09 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
pulley
Re: how the f@*k to pull an alternator pulley? [Re: dirtybee] #866903
11/30/10 12:13 AM
11/30/10 12:13 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
tool and fsm. and so sorry if i offended with my edited cursing.
Re: how the f@*k to pull an alternator pulley? [Re: dirtybee] #866904
11/30/10 12:17 AM
11/30/10 12:17 AM
that looks like the puller i use on the bath tub handles when plumbing
I didnt hear you say a thing,i read it so its all good to me
I would try a bearing spliter and press
Re: how the f@*k to pull an alternator pulley? [Re: scratchnfotraction] #866905
11/30/10 12:31 AM
11/30/10 12:31 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
thanks scatch'n, unfortunatly i don't have a splitter but it may be worth the investment, at this point from what everyone said i think i'll just run the 2 3/4" pulley. but if you look at the fsm picture under the tool. they are the same i'm just pissed i fudged a brand new shiny part do you think i'll be ok running the pulley like that?
Re: how the f@*k to pull an alternator pulley? [Re: dirtybee] #866906
11/30/10 12:43 AM
11/30/10 12:43 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
the bent flange wont hurt a thing. And that alt, couldn't care less what gear your running.
Re: how the f@*k to pull an alternator pulley? [Re: drew72] #866907
11/30/10 01:00 AM
11/30/10 01:00 AM
other than looks its still good and still shinny
yea I would run it and not worry about that pully
as far as juice,i uped mine to a mini alt on my 440 in the sig pic
it was a bolt on,,double pully,external regulated,120 amps,smaller/lighter
yea thats the correct puller/i was just sayng it looked like the cheapy one for plumbing I have handles
Re: how to pull an alternator pulley? [Re: scratchnfotraction] #866908
11/30/10 01:27 AM
11/30/10 01:27 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
This puller works and it goes on sale all the time for 50% off.
Pulley Remover and Installer Set
Re: how to pull an alternator pulley? [Re: Snoopy] #866909
11/30/10 01:30 AM
11/30/10 01:30 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Nice job Snoopy, the correct tool and a proper thread title...
Re: how to pull an alternator pulley? [Re: 1_WILD_RT] #866910
11/30/10 02:09 AM
11/30/10 02:09 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
thanks i will look into that tool. i did scramble the letters in my title( which i have now changed) geez, I'm just venting/ kidding around, my apologies to all that found my title offensive.
Re: how to pull an alternator pulley? [Re: dirtybee] #866911
11/30/10 02:13 AM
11/30/10 02:13 AM
Conyers, Georgia
72chargerz Offline
72chargerz  Offline
Conyers, Georgia
The problem is that your pulley removal tool is a piece of junk. I have one just like it and have had similar results.
Re: how to pull an alternator pulley? [Re: dirtybee] #866912
11/30/10 02:26 AM
11/30/10 02:26 AM
AndyF Offline
AndyF  Offline
Pulling it is easy. Pressing it back on is a pain. One more reason to switch over to a modern alternator like the Denso. Not only do the work a lot better, they are easier to work on.
Re: how to pull an alternator pulley? [Re: AndyF] #866913
11/30/10 02:41 AM
11/30/10 02:41 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
thats great news after i just recieved my new $150 cdn tuff stuff 100 amp alt....jk
Re: how to pull an alternator pulley? [Re: Snoopy] #866914
11/30/10 09:50 AM
11/30/10 09:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Go to Advanced or Auto Zone.They have the pullers in their loaner tools.Looks like 2 halves that go around the outer flange.There is a sleeve that fits over them and a threaded bolt that goes into a big flat piece.they are easy to pull.Ive done hundreds at work.As said he alt needs to be split to press on although I have pressed a few on without spliting them.Rocky
Chrysler Firepower
Re: how to pull an alternator pulley? [Re: Snoopy] #866915
11/30/10 10:01 AM
11/30/10 10:01 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Same sort of puller for Federal power steering pump pullies, too...
Re: how to pull an alternator pulley? [Re: Sixpak] #866916
11/30/10 06:37 PM
11/30/10 06:37 PM
Snoopy Offline
Snoopy  Offline
I modified the puller screw in the kit I bought. The original screw had a tendency of cutting threads into the inside of the puller if you weren't paying attention to it's location.
I just chucked it up in my drill press and took a file to it.
