Indy 440-25 + Holleys = ?
#865283
11/28/10 03:12 AM
11/28/10 03:12 AM
Posts: 28 Godfrey, Il
muntz1
Godfrey, Il
Has anyone tried holleys on the 440-25 intake? If I'm reading the NMCA rules for NSS right they allow them in the FX classes. I will probably have my stock edelbrocks reworked, just being curious.
Re: Indy 440-25 + Holleys = ?
[Re: muntz1]
#865284
11/28/10 11:01 AM
11/28/10 11:01 AM
Posts: 9,897 MI, usa
dvw
MI, usa
Jake tried them on Lens 63. He said it made better power on his Chassis Dyno with the Carter/Edelbrocks. The car went faster as with them as well. In September at Norwalk 8.99@150. Nice looking car by the way. I'm doing a 64 Belvedere. My neighbor is building a black 64 Polara 500. Both for N/SS. Doug
[Re: muntz1]
#865286
11/28/10 02:16 PM
11/28/10 02:16 PM
Posts: 684 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Chuck at Best Machine ran them on his 440-25 when he had it. Paul Habura tested with them on the dyno, he actually got a set of his eddy's to darn near match the performance of the holleys. You also have to get different plates for the top of the intake. What does that car run? looks good! Casey
[Re: Whompin_Wedge]
#865289
11/28/10 05:23 PM
11/28/10 05:23 PM
muntz1
Godfrey, Il
keleno block, 540ci, 14.1 comp, steel rods, some old 383-13 heads, and best machine's bracket cam - yes, Chuck put it together. Great guy to deal with. The edelbrocks are definiely easy to work on. Thinking of having Damon work them over. I was told that removing just the choke horn was worth 11 hp but don't know if it is true. Picture of your car from the monster
[Re: muntz1]
#865290
11/28/10 07:14 PM
11/28/10 07:14 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
Hey good to hear the car is running good! Have Damon do your carbs he is very good on these carbs and a good friend.Can't wait for next Monster...we can tear the beer up again poppaj
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: Whompin_Wedge]
#865293
11/28/10 08:10 PM
11/28/10 08:10 PM
muntz1
Godfrey, Il
Always ready for a Thanks for the offer on the plates, I'm not sure what I'm going to do yet but will probably stick with the edelbrocks. I'd love to put stack injection on it but I don't know if I'm ready for the extra work. A toilet would be cool but I don't think it is "era-correct" Dave
[Re: sjs64polara]
#865297
11/28/10 09:15 PM
11/28/10 09:15 PM
muntz1
Godfrey, Il
As I remember AndyF did a test and it was worth 70hp. The holleys would have to be mounted sideway. From the looks of the above post from pentastar440 the linkage could be complicated. Didn't think of that.
[Re: sjs64polara]
#865298
11/28/10 10:48 PM
11/28/10 10:48 PM
dvw
MI, usa
My engine is a 505, Victor Max wedge heads, Rick Allison cross ram, and 835 Ken Jones Holly carbs. How much HP could be added using the Indy set up Also can they be inline or only sideways My current engine is 730 hp on pump gas and 10.75:1 [/quote I dynoed my old 498 with one of the first ever Indy manifolds. Crossram 658@5750, Indy 707@6750. It was good for 49 HP and 1000 rpm in engine speed. With the right combo its worth probably close to 100HP. Don't give up on your Crossram yet. Treat the motor with its intended lower RPM level. You can go low 10. Doug
[Re: muntz1]
#865299
11/28/10 10:50 PM
11/28/10 10:50 PM
dvw
MI, usa
Thanks for the reply. Looks like your car is comming along nicely. I didn't think it would make much difference but I'm looking for just alittle more power. Didn't get the car going until late in the year and didn't get very much T&T done to get it where it should be. It's even going to be harder to T&T with gateway in St. Louis closing. I'm going to try and take some weight out and add a vacuum pump for a winter project. Would like to try injection but i don't think I'm ready to tackle stacks yet.
Talk to Clay Kossuth about the injection. He has run it for awhile. I'd love to do it as well. Doug
[Re: dvw]
#865300
11/28/10 11:20 PM
11/28/10 11:20 PM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
My engine is a 505, Victor Max wedge heads, Rick Allison cross ram, and 835 Ken Jones Holly carbs. How much HP could be added using the Indy set up Also can they be inline or only sideways My current engine is 730 hp on pump gas and 10.75:1 [/quote I dynoed my old 498 with one of the first ever Indy manifolds. Crossram [Email]658@5750[/Email], Indy [Email]707@6750.[/Email] It was good for 49 HP and 1000 rpm in engine speed. With the right combo its worth probably close to 100HP. Don't give up on your Crossram yet. Treat the motor with its intended lower RPM level. You can go low 10. Doug
Thanks for the kind words but I'll need to put my self and the car on a diet to go that fast. Current weight with me is 4070lbs. I'm 246lbs.I'm going to glass bumpers, removing the under coating, dynamat, center consule, and going to plastic seats this winter. Hopefully that will help I could stand to drop 40-50lbs too
[Re: sjs64polara]
#865302
11/28/10 11:31 PM
11/28/10 11:31 PM
muntz1
Godfrey, Il
I have talked to Clay about the stack injection and tried talking me into it - says the throttle response is insane and picked his car up a couple tenths. I have a couple friends that run toilets and say the same thing about the response. Don't think a toilet would be allowed in NSS/FX racing classes as a second option because it isn't era-correct.
