Re: Need opinions: 440 EFI procharger/intercooler
[Re: BombSquad]
#864742
11/27/10 02:07 PM
11/27/10 02:07 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
hmmm...
1000 hp billet mains/girdle cheapest heads on the market Edelbrock EFI 4L80E transmission Pro Touring (looks purty but will likely never see a race track) Working on a budget
Some of these things do not fit together.
[Re: BombSquad]
#864745
11/27/10 04:10 PM
11/27/10 04:10 PM
feets
Senior Management
Senior Management
Irving, TX
I hope you realize how difficult it is to hook up big power with low profile tires. I run a 295/45-18 which has a 5" sidewall. That tall of a tire still has issues holding on to my mild build with 3.23 gears and a stock converter. Adding another 350 or 400 hp would make it even more difficult.
A car like you're describing (I hate the term Pro Touring) is a compromise of EVERYTHING.
Good power but a fat power band. Stiffer suspension but not harsh. Sticky tires but wear and all weather traction is a concern. Strong drivetrain but nothing that bangs or slams on shifts. Stiff chassis but it can't rattle your teeth out. Lighter weight but keep creature comforts. Blower hanging off the side of the engine that doesn't interfere with the A/C compressor. Big brakes that aren't harsh and have readily available replacement parts.
Sure, you can hack it together like I did but be aware that you will have to give a little here and there to make it work. Cars like the Big Red Camaro are nifty but have more money in them than I spent on my house. Like anything else, it's a money game.
[Re: BombSquad]
#864747
11/28/10 01:17 AM
11/28/10 01:17 AM
feets
Senior Management
Senior Management
Irving, TX
I've been looking at the FAST and Pro-Flo systems but I don't know enough about them.
I can't afford to make any changes so it's not a priority for me.
[Re: feets]
#864748
11/28/10 05:37 PM
11/28/10 05:37 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
the 440 rods and crank would be my concern if you're planning over 1,000 hp.
I have the tyres you mention 345 PS2's. Pic:
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Keith Black®]
#864749
11/28/10 05:39 PM
11/28/10 05:39 PM
Keith Black®
QLD Australia
sorry, I meant "440 Source" rods and crank,
[Re: Dragula]
#864752
11/29/10 10:03 AM
11/29/10 10:03 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Its the idle concerns for big injectors on a smaller engine, I also have 83's on a mild 500 inch (prior to the procharger). As long as you have a good charging system, you should be good with the larger injector.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Mr.Yuck]
#864754
11/29/10 12:27 PM
11/29/10 12:27 PM
feets
Senior Management
Senior Management
Irving, TX
Because on the street you'll be far happier with EFI than with that carburetor junk.
Yuck, your piss poor attitude is showing again.
[Re: feets]
#864755
11/29/10 12:55 PM
11/29/10 12:55 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
not against EFI,,, have at it. but 1000hp for something somebody is just going to tool around in????
[Re: Kam*Kuda]
#864756
11/29/10 01:30 PM
11/29/10 01:30 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I run 83 pph injectors on a 135 cubic inch motor.
[Re: gdonovan]
#864757
11/29/10 05:31 PM
11/29/10 05:31 PM
Keith Black®
QLD Australia
I'll be running 16 x 95lb injectors. The pulse widths are very narrow @ low engine speeds/loads with large injectors and I don't want a poor tune. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Keith Black®]
#864758
11/29/10 05:55 PM
11/29/10 05:55 PM
gdonovan
Oakdale CT
Enough for 1174 hp at 85% duty cycle.
I'd not worry too much about the injector size, some folks on the turbo dodge team are running 130 pph injectors.
My Reliant starts and idles like a stocker and runs stock electronics.
Yes, I do my own calibrations.
[Re: Quicksilver440]
#864760
11/29/10 07:20 PM
11/29/10 07:20 PM
gdonovan
Oakdale CT
I could be wrong....and you are more experienced than I. But I would be concerned that if injectors are WAY TO BIG...you could have idle pulsewidth issues. This was based on my assuming he meant run like a 650 hp engine on 80lbs injectors.
I run a 4 banger with 83's and friends of mine run 130's. One just ran 8's with a Dodge Shadow.
His injectors will be fine, hell I use to pass state emissions with no cat with 52's.
People talk theory all day, some of us do actually walk the talk and can provide feedback.
